loading
Step 10: Build the Roof
Build the roof after the bond beam is finished. Any type of roof is possible, and space doesn’t allow a lengthy discussion. We used a metal compression ring with radiating wood poles covered in thatch. Create large roof overhangs of approximately 30”-36” to protect walls from moisture damage. The exact size will depend on your climate.
The roundhouse has a super strong feeling due to the concrete bond beam, thick walls, sturdy poles and round shape. You could probably have a dozen workers on the roof with no visible effect. The roof frame went together almost like clockwork. The compression ring worked perfectly. The roof was all bolted together in about 4 hours, in part because the poles were precut and prefinished in advance.
Thatching is usually very slow and laborious, but we thatched our roundhouse in just one day and for only $100 using pre-made thatch panels. That's why I love thatch panels - they're very inexpensive and all the tedious work has already been done. And they work great on round (conical) and organic shaped roofs because they're flexible. Just bend them into position and nail in place. We installed the panels using 8" spacing. Plan on rethatching every 3-5 years or so, depending on the quality of your thatch. Some thatch will last 10 years or even longer.
In cold climates you’ll want a thick roof with lots of insulation. This can be achieved with trusses or TJIs (engineered truss joists). Wide dimension lumber could also be used, however, this requires cutting old growth forest.
<p>Hi! Thank you so much, for your time in sharing this knowledge. I live in the North Carolina Appalachian Mountains. We are quite elevated , and have very moist , soft soil on slanted land. There was an old large barn , on the property that was built in the 40's which burned down some time ago. The cinderblock base is still there ( well 2 opposite walls, actually) that were placed with steel rebarb? Regardless, they are not going anywhere, according to a contractor friend. My thoughts were to build a floor/deck on top then build a earthbag structure/studio on that. Any thoughts as to reinforcements, drainage, would it be too heavy for the raised wood deck/floor?</p>
Earthbag walls are very heavy. You need a foundation the same width as the bags (about 16&quot;). One option is to stack gravel bags next to the block foundation on the outside. The floor joists could sit on the block walls (add a plate first). Follow the instructions in my earthbag book that include stacking the bags on a rubble foundation.
<p>Hello, Your Earthbag Rounhouse Building tutorial is excellent and I am really keen to build one. I live in the UK where it is wet. Do you think this would be suitable? I was thinking of building a concrete base with glass bottles and plastic layer under the concrete for insulation and then putting the bags on top. Would this work or do I need the them on the ground with gravel for drainage?</p>
Earthbag buildings are common in the tropics where there's lots of rain. No problems as long as you build correctly -- wide roof overhang, build on high ground, slope the site away from the building, etc. <br><br>The bottle foundation sounds unnecessarily complicated. I recommend bags filled with an insulating material such as volcanic rock or expanded clay pellet insulation.
When you say lava rock.. does basalt count as that? There is so much basalt all over my area
It will provide insulation if it's lightweight and porous like scoria. This is discussed in detail on our Natural Building Blog.
<p>Hi Owen! Thank you for this instructable! Are you familiar with sunken earthbag roundhouse designs? I have an opportunity to purchase several acres in arid Yakima Co, Washington. I think that I will be acquiring a 30 ft yurt soon. I would like to make a sunken earthbag roundhouse/yurt hybrid home. Essentially, I want to dig a 29ish foot diameter/ 6 foot deep hole; build a roundhouse with 11 foot walls with no roof and set up the yurt snugged around it. I would like to put in earthship style passive cooling tubes to help with combating the summer heat and a mass rocket stove.for winter. The building would look like a yurt from the outside but be much more expansive on the inside( I have a husband, three children and a mother in law in my immediate family). With that space we could construct a loft platform for my husband's mom. Have you heard of anything like that? I'm not sure where to get a designer to draw it up so I have a chance of getting a permit. I think in would be beautiful and much more affordable then a conventional home as my family, friends and I would be doing all the work. I would appreciate any advice you could give regarding such a build. Thanks in advance!!</p>
Building below grade has high risk of water problems without a properly sealed foundation with French drain. I don't recommend it. One big rain and it could fill up with water.<br><br>Earthbags are very energy efficient if you insulate the outside with rigid foam board. The thick earth walls will stabilize the interior temperature, keeping it cool in summer and warm in winter. You do NOT need to dig down to keep the house cool, because earthbag houses are cool even in the tropics where it's much hotter. This will save you lots of work, money and headaches.<br><br>Hire a high school art student who knows how to use a graphics drawing program to draw the house.<br><br>This is the method that I recommend for yurts:<br>www.instructables.com/id/Insulated-Earthbag-Foundations-for-Yurts/
Okay. Thank you for your feedback! I really appreciate it!
Greetings Owen,<br>I love what i see!<br>I planing to build few cabins like this on my land in Jamaica. Im extending my guesthouse Jardin d'Eden Jamaica. Do you have a team who travel and give a hand? We will start very soon! I can offer accomodation, food and a super great time :)<br>Please email me melissadauphin7@gmail.com<br>
<p>Hi Owen, hope you are well! I am planning on trying my hand on the round studio, its really super cute. How long would it take for 1 skilled contractor and two strong but unskilled workers to build the studio? Thanks. Saskia</p>
Around 7-10 days with bags if they know what they're doing. Tubes are about twice as fast.
<p>Thanks for your answer Owen, thats pretty fast. Ill just double that because we are totally new to the system :)</p><p>Tubes; how do you look up where to buy them? My agro-veterinarian places have never heard of them. </p><p>Thanks again! Saskia</p>
<p>This is beautiful I like it &amp; I can't wait to create my own ! </p>
<p>Beautiful building; I like the round design, but I wonder, how would these walls hold up if stacked vertically, in the more traditional manner? That bond beam looks like it can support basically any kind of roofing type. I'm thinking a man who wanted to own an (eventually) sprawling home could just stack more bags and plaster them to add on to any house. <br><br>Maybe I'll start with a shed...</p>
<p>Yes, start with a shed to develop your skills. You can use any roof method you want. You can add on in the future if you plan for it. I don't understand your first question. The walls are stacked vertically in this roundhouse.</p>
<p>Hello!</p><p>Can I fasten shelves and things like it? How does the walls behave with screws?<br></p>
My earthbag book covers this topic Attaching Things to Earthbag Walls.<br><br>Add wood blocking between the bags as you build. That way you can screw cabinets, shelves, etc.into the blocking. Same with electrical. This requires a bit of pre-planning to figure out where you want to put things.<br><br>Lightweight things can be supported with big nails or 1/4&quot; rebar pins drive in at a downward angle.
<p>Thank you so much for this tutorial. It was so easy to follow. and now im here dreaming about building my dream home in joshua tree.....</p>
<p>I always wanted to make a house like this, but use used tires packed with dirt for the outside walls, get rid of the old tires, and nothing can beet 2 feet of earth as far as insulation goes. </p>
Earthbag is quite similar to rammed earth (an ancient building method). That's the same rammed earth in the tires. Except here we're using bags instead of tires. Making earthbags is so much faster and easier there's no comparison. One rammed tire takes around 45 - 60 minutes from what I've read. You can do one earthbag in five minutes. Using tubes is even faster. Maybe twice as fast. Plus, there's no concern over offgasing. The wall surface is flatter and uses far less plaster than filling gaps between tires.
<br>what is the best material to use as a divider to make a bathroom in a round earth house?<br>
The &quot;best&quot; solution depends on what materials are locally available, durable, practical and affordable, and on your skills. We used low fired clay brick because it's waterproof. Most people use wood framed walls with the pipes in the walls. Our pipes are on the surface (local custom) so they're easy to maintain.
Hi Owen,<br>Im planning to build an earth bag round house.<br>can you send me a floor plan where to place sink and bathroom.<br>
<p>The Roundhouse Studio plans are available at Dream Green Homes.com.</p><p><a href="http://dreamgreenhomes.com/materials/earth/earthbags.htm" rel="nofollow">http://dreamgreenhomes.com/materials/earth/earthba...</a></p><p>But this plan is so simple and this Instructable explains everything so you may not need the plans. In general though, the sink and bath are usually adjacent to each other to simplify plumbing.</p>
<br> <br> Beautifully earth bag house look nice cost is also less. This roundhouse <br> demonstrates how anyone can build their own home even on a very tight budget. <br> For those who are not living that type of home, take <br> care in weather changing so that could live safely specially for roof it is <br> worst time. Keep EPDM with you as precaution. For more to know please visit <br> <br> http://www.epdmcoatings.com/ <br> <br> <br> <br> <br> <br>
<p>EPDM is very expensive. I would only use it on a living roof if the budget allowed. Metal roofs are much less expensive.</p>
<p>Do you have any resources or advice for building a double storey roundhouse? I am beginning to build in the New a Year (2015) and am starting to plan the details...thanks!</p>
<p>I just emailed you. Use lightweight building materials on upper stories because soil is very heavy.</p>
Would Lime plaster work well on the exterior walls? Or gypsum plaster? I'm in Central Oklahoma, by the way, with our weird weather patterns. Long dry (as in no rain) summers with high humidity, moderate winters with fairly low humidity, and two rainy seasons... spring being the main one, the second being in the fall. Clay soil, so flooding happens easily and slab built buildings usually do flood. <br> <br>Leigh
<p>Up to you. Cement plaster is the standard and likely the most resistant to flooding.</p><p>Water is the #1 enemy of buildings, so raise your building site above flood stage or building on high ground. Use gravel bags on lower courses. Plastic sheeting under the floor to prevent wicking. Slope the ground away from the building in all directions.</p>
<p>You can use cement or lime plaster. Some mix the two. Recipes are free on the Internet.</p>
Lime plaster is great. Read up on the details and follow the instructions. <br> <br>Raise the building site above flood stage. We did this by dumping truckloads of road base in 6&quot; layers and driving a truck back and forth over the top in opposite directions.
<p>Hi Owen, loved your article. I live in Michigan and we tend to have crazy winters here. I'm wondering if a project like this would be feasible in our high humidity environment. </p>
<p>Yes, but you need to modify the design for your climate. This one is for the tropics. You want fewer windows, insulating south facing windows, roof insulation, durable roofing, lots of wall insulation, floor insulation, heating system, insulated door, etc. Read up on climate appropriate design or climate responsive design. </p><p>http://collections.infocollections.org/ukedu/en/d/Jsk02ce/3.4.html</p>
<p>Awesome! thank you very much. you have been incredibly helpful</p>
On the floor... if using earth floors, would I need to put down a moisture barrier, between ground and scoria, possibly tamped sand also? I'm concerned about moisture wicking up the walls from the ground under the floor. Our heavy clay soil doesn't drain well, and I have enough health problems without adding mold in the house on my walls to the mix. <br> <br>Leigh
<p>Yes. Add a layer of sand and then plastic sheeting and then do the floor. That will prevent moisture from wicking up into the floor.</p>
Yes. Use typical plastic sheeting, also called 6 mil poly.
This is absolutely amazing! I think I'm going to give it a try. <br> <br>Do you know how these homes are affected by strong vibrations? I like to crank up my music sometimes and my current home shakes quite a bit when I do... I'm not sure if the heavy walls would be unaffected or if the dirt walls would crumble. <br> <br>Thank you so much for the instructable and a reply if you have time!
<p>No problem.</p>
<p>Don't worry, the walls won't vibrate or crumble. The walls are incredibly strong. The army uses similar construction methods (sand bags) to store loads of ammunition. The ammo bunkers are next to each other. If one bunker blows up, the other bunkers won't blow up.</p>
Hello Owen <br>Your building methods are astoundingly simple and effective &ndash; they just make sense. I live in Thailand and I want to build an earth bag roundhouse, a larger one that the 177 sq ft that you built here. I'd be interested to know where in Thailand you built the round house? Also, and more to the point, your mention of the materials being $11.50 per square foot was that the price in Thailand? <br> <br>Thanks <br>Peter McLaren. Udon Thani <br>
<p>Yes, that's the price in Thailand. I live in Isaan.</p>
You can email me at:<br>naturalhouses [at] gmail dot com
Hi Owen <br>I find your ideas very inspiring <br>I intend to build a big roundhouse about 33 feet diameter in Udon Thani Thailand. It seems to me that the roof will present a problem in that I can&rsquo;t think of any cheap material to build it with. I don&rsquo;t want thatch because of the insects and the short life span of such a material. I actually want to include a central pole/tree trunk as an interior feature rather than using a compression ring. <br>I can get bamboo for next to nothing and cover the roof with it which should look good from the inside but I&rsquo;m at a loss then to know how to waterproof it on the outside. I don&rsquo;t want to have to screw tiles to the bamboo if I can help it. <br>I also want to build the site up with soil to about half a metre AFTER I build the house. So I think I need a solid foundation. If I make the foundation slightly higher than half a metre and us earth two bags side by side where do I place the single earth bags for the walls&hellip;&hellip;.in the middle of the two? <br>
<p>I hope you see this. It's been a year already. We replaced our thatch with MCR tiles (super popular in Thailand). They should last 25-30 years. They're quite easy to work with. I would build a wood pole roof structure because bamboo in Thailand is too unpredictable unless you've thoroughly done your research and treated the bamboo.</p><p>Lower walls for earth berming: You could use regular bags all the way if the berm is only 24&quot; high.</p>
Foundation: Set the center post first then start your walls. Use doubled gravel bags or tubes (one inside the other) for added strength. Make sure you start on solid ground because earthbag walls are very heavy. Make a rubble trench under the wall. Do half a meter of gravel bags and then add fill material on the inside and outside. Road base is an excellent choice. Slope the ground away from the building in all directions. This will give you a raised floor. Do one more course of gravel bags before starting regular soil filled earthbags.<br><br>Roof: You can use bamboo, wood or metal framing. Bamboo is rather difficult to work with and requires treatment to prevent rot. It's not commonly used in Thailand and you'll have a difficult time finding what you need. Metal framing is actually a good choice in Thailand because it lasts a very long time and is affordable in Thailand. (It's the standard construction method now.) For roofing you can use metal roofing (often the best choice), micro concrete tiles (can still collect roofwater but not so noisy), wood shakes (hard to find) or ferrocement. You can email me at natural houses [at] g mail dot com for further details.
Any success with structure shapes besides &quot;round&quot;? Can you free form the design in a fashion similar to the &quot;super adobe&quot; style or . . . ? <br>Also: what kind of size/span limitations have you encountered with this method? <br>
About This Instructable
416,667views
888favorites
License:
Bio: Owen Geiger is the former director of Builders Without Borders, a Mother Earth News Green Home Adviser, The Last Straw Journal Correspondent and the director ... More »
More by Owen Geiger:Earthbag Water Tanks Insulated Bamboo Walls Insulated Earthbag Foundations for Yurts
Add instructable to:
