How to Build an Insulated Earthbag House
 by Owen Geiger
For those new to earthbag building, please read my Step-by-Step Earthbag Building Instructable . Also, my new Earthbag Building Guide and Earthbag Building DVD are now available.
Energy performance on most buildings can be improved with insulation, including those made of earth such as adobe and earthbag structures. Although most earthen structures are located in hot, dry climates, there is increasing demand for low-cost, eco-friendly earth building techniques in cold climates. This article explores four innovative methods for insulating earthbag buildings, which extends their building range to cold regions.
Most earthbag buildings use polypropylene grain bags or mesh bags filled with soil. Bags or tubes can be used. We demonstrate bags, because they’re often available recycled for very low cost. The bags or tubes are filled in level courses and then tamped solid. There are typically two strands of barbed wire between courses to bond the bags to each other and add tensile strength. The building process for insulated earthbag houses is nearly the same, although the materials would weigh significantly less and speed construction considerably.
Unlike other earth building methods, earthbag building has the unique advantage of providing either thermal mass or insulation, and therefore can be adapted for cold climates with an insulated fill material. Scoria, pumice, perlite, vermiculite or rice hulls are all suitable insulating materials. These materials are natural, lightweight, easy to work with and non-toxic. Most (all but rice hulls) will not burn or rot and do not attract insects or vermin. In addition, all but rice hulls are not adversely affected by moisture and can be used as part of earth-bermed or earth-sheltered structures. Recycled polystyrene (Styrofoam) is another good possibility. Another possibility is adding foam board or foam insulation on the exterior of earthbag walls, as explained in the 4th option.
The table below compares the approximate R-values of five low cost insulating materials that could be used in earthbags. (The first column in the table is the insulative value per inch; the second column shows the R-value for a typical 15" thick earthbag wall.)
Material -- R-value/inch -- R-value/15"
Rice hulls -- R-3 -- R-45
Perlite -- R-2.7 -- R-40
Vermiculite -- R-2.13 -- R-32 to 36
Extruded polystyrene -- R-3.6 to R-4.7 -- R-54 to R-70
Molded polystyrene (low density) -- R-3.85 – R-58
(Source: Wikipedia Encyclopedia.) http://en.wikipedia.org/wiki/R-value_(insulation)
Tools and supplies:
Shovel, bucket, garden hose, tamper, slider, gravel, soil and/or insulation, earthbags (poly sand bags), barbed wire, wire cutters, level
The following pages discuss four low cost methods of building insulated earthbag houses.
For more information, my You Tube Channel has dozens of short videos showing every step of earthbag building.  And our Earthbag Building Blog , the number one blog on the subject, covers every aspect of building with bags in detail.
Step 1: Bags or tubes filled entirely with insulation
The first and simplest method for insulating earthbag buildings uses bags or tubes filled entirely with insulation. The main advantage of this method over the other methods described below is ease of construction. Walls are one bag wide and filled entirely with insulation. Thick earth or lime plaster on the interior provides thermal mass to help stabilize indoor temperatures.
A demonstration home using this method was built in Crestone, Colorado with scoria-filled earthbags. Scoria is also known as volcanic rock or lava rock. It’s widely used in landscaping. Due to its volcanic origin, scoria is filled with tiny air spaces, making it a good insulator. Although the R-value of scoria is debatable, the owner claims these earthbag walls are comparable to straw bale walls of around R-26 to R-30. This estimate includes 5" of papercrete at approximately R-2/inch.
Building a load bearing structure with bags of insulation in this way is still experimental. We’re confident in the working properties of scoria and pumice, but using other types of insulation needs more research. For instance, some types of insulation may compress excessively under loads. Lightweight walls of insulation are not as sturdy as bags or tubes filled with soil and may require some temporary braces. Tubes tend to roll. Round or curved building shapes are more stable than rectangular. Adding vertical bamboo or rebar pins tied together through the wall may be needed. You might also need to use a post and beam system to provide additional support and to meet code. Start out with a small test structure to improve your techniques. It would be great if someone would build some small test structures and document the results. You can join the discussion about Perlite Roundhouses on our blog.
The photo below is of Kelly and Rosana Hart’s Dome Home . Their home has been published in at least 10 books and magazines. Kelly is the owner/author of the number one most popular sustainable building website GreenHomeBuilding.com . His site covers every green building method.
Step 2: Tube sandbags filled with insulation on the exterior of earthbag walls
Another method for insulating earthbag buildings uses tube sandbags, also called traction tube sand bags, typically used to improve automobile traction on snowy/icy roads. (The bags are sold to add weight for vehicle traction.) This method involves stacking tube sandbags filled with insulation on the exterior of earthbag walls, thereby creating a double wythe wall joined together with poly baling twine or with barbed wire.
Tube sandbags provide about 10" of insulation, which is perfect for many climates - not too much, not too little. Again, scoria, pumice, perlite, vermiculite, polystyrene or rice hulls could all be used for insulation. Perlite and recycled polystyrene would be my first choices due to their high R-value and resistance to moisture damage, although the final decision needs to be weighed against other locally available and inexpensive natural materials.
Step 3: Make a seam lengthwise down earthbags to create two compartments
A third possibility is to add a seam lengthwise down earthbags – either 18” or 24” wide bags – to divide them into two compartments. The outer part could be filled with insulation; the inner part with soil. Like the other systems described here, this would create an insulated wall with thermal mass on the interior. For many situations, especially structures in moderately cold regions, this is an ideal wall system, although the bags would be somewhat awkward to fill.
The placement of the seam could vary, depending on the climate. In a mild climate like New Mexico, about 4"-5" of insulation on the outside would suffice. This would provide about R-10 insulation. In a slightly colder climate the seam could go down the middle (50% insulation / 50% soil). In extremely cold or extremely hot climates I would fill the bags with 100% insulation (or all earth in a hot climate if insulation is not available).
Step 4: Reinforced earthbag system
A fourth option utilizes the reinforced earthbag system developed by Precision Structural Engineering, Inc. (PSE). Simply add foam board insulation or spray foam insulation on the exterior of earthbag walls. This is probably the most practical approach if you need a building permit. PSE is licensed in 27 states, and they also have reciprocal relationships with engineers around the world that would enable you to get engineer approved plans and building permits almost anywhere. Their fees are quite reasonable. This building system has been covered in detail on our Earthbag Building Blog. Here’s the link to their Reinforced Earthbag Specifications .
Corynder says: Mar 30, 2013. 8:49 PM
Hello :) My friend is looking into different possibilites regarding building on her land. The problem is that her land is very sandy and so things I have some experience in (such as mudbrick) aren't going to work. But I think that could also be a great asset as well if we figured out how to use it right.
How is sand for a filler? As insulation? I'm guessing it's not very flammable, which is great, but would you recommend it or mixing it with something?
Owen Geiger (author) in reply to CorynderMar 30, 2013. 9:36 PM
Mix some clay with the sand until your test bags dry hard and strong. Or you could add a little cement or lime to the sand as stabilizer. You could also search our Natural Building Blog for the building method developed by Eternally Solar. Their specially designed tubes (which you could make) are designed for sand. You can use their system free of charge if it's non-commercial. All details are provided if you search the site.
mountainviewoffgridliving says: Dec 10, 2012. 9:03 PM
We've purchased your books and are about ready to start buying what we need to get started. I am finding a lot of contractors advertise their leftover building materials on Craigslist so we are picking up things now for either very little or for free like windows, doors, boards, etc. Our next purchase will be the bags and barbed wire. We want everything we need while we can still buy things. We just purchased a Kimberly Stove and after the earthbags we will buy a Sun-Mar Composting toilet. We should be really close then to having what we need... or at least I hope so. I absolutely love earthbag houses but especially like the earth bermed one. We want an earth bermed house with a green house on the front side. Thank you so much for getting this information out!!! We are buying land in a county that does not require building codes. How are others doing this in counties that require a permit for everything? Are they having any problems getting permits for this type of building? Thank You.
Owen Geiger (author) in reply to mountainviewoffgridlivingDec 10, 2012. 11:17 PM
It sounds like you're making all the right moves as far as planning ahead, buying used materials, etc. Choosing a county with no building codes can save you thousands or even tens of thousands of dollars. For instance, most areas require certain room sizes and overall minimum house size with covenants, etc. So instead of building a 1,000 sq. ft. box for instance, you can build just what you need and want. You can always add on later, so we always recommend starting out small and simple. Also, codes require lots of extra steel and concrete. In your case you can build an earthbag foundation instead of concrete. That one step alone can save you $2,000 or more depending on where you live and the size of your home.
Be sure to read my instructable on How to Build Dirt Cheap Houses.
http://www.instructables.com/id/How-to-Build-Dirt-Cheap-Houses/
It describes how you can save thousands of dollars on every step of construction. But like you know, this is only possible if you live where there aren't any codes. Plus, you'll be more free to grow your own food, raise chickens, dig your own well for self sufficiency, etc.
And yes, building in building code areas is much more difficult as you can imagine. It can be done, but it's a lot more time, money and effort.
candyland22 says: Mar 27, 2012. 9:55 PM
I have just stumbled upon earthbag homes about 2 hours ago and have changed my mind from a log home kit to this! I live in upstate Ny and recieved some land from my mother in law in the adirondacks! Would these homes be ideal for the weather conditions? If we had a outdoor wood furnace could we run the heating pipe through the wall without damaging anything? My husband and I are not very construction savvy! Also how do you run electric? Thank you in advance! :)
Owen Geiger (author) in reply to candyland22Mar 27, 2012. 10:12 PM
You have to weigh all the advantages and disadvantages and decide what's best for you. No one building system is perfect for all situations. For instance, maybe you have an abundance of wood that could be used for cordwood building. Or maybe you have excellent stone for building. Or low cost straw bales from a local farmer...
Everything you need is free on our various websites -- YouTube, EarthbagBuilding.com, Instructables, Earthbag Building Blog. Just google it. Every topic such as how to install electrical is shown in detail.
No problem running pipes through the wall for a wood furnace.
If you do go with earthbags in NY or other cold climate, you'll need to add insulation. Here's one of many free articles that will help you: http://www.instructables.com/id/How-to-Build-an-Insulated-Earthbag-House/
candyland22 in reply to Owen GeigerMar 28, 2012. 12:13 PM
Now if we decided to expand our earthbag home, how could that happen? Is it possible or would it risk the strength of the structure to cut a doorway out into another room? I also was playing with the idea of a mix of earthbag and cordwood for a more dynamic look.
Owen Geiger (author) in reply to candyland22Mar 28, 2012. 5:23 PM
It's best to plan ahead because it's difficult cutting out doorways later. One way is to frame a window opening like a door so it's easy to convert to a door later. (Bags sit inside the buck under the window.) Cut the plaster next to the buck, knock out the bags and there's your framed door opening.
Our blog talks about how to use buttresses to join new earthbag walls in the future. This and all topics are covered in detail in 1,100+ blog posts. Use the built-in search engine or buy my Earthbag Building Guide book that summarizes all the most important info. http://www.earthbagbuilding.com/articles/ebbuildingguide.htm
Joining cordwood and earthbags is easy if you make the cordwood the same length as earthbags (about 18").
candyland22 in reply to Owen GeigerMar 28, 2012. 9:27 PM
Thank you for all your help so far! Im purchasing your book as soon as the land is in my name! I was GIVEN 5 beautiful acres (thank you mother in law) so this really is going to be quite the low cost home!
CarolAnn525 says: Jan 11, 2012. 4:46 AM
Hello Owen,
My husband and I just got your book and are very excited about building.
We are planning to build in northern Minnesota and are wondering if anyone knows of an earth bag home in this state. I know of a straw bale home but not an earth bag. Would the building codes for earth bag be the same as straw bale, or comparable?
Also we plan on a 50/50 mix of volcanic rock to native earth. Do you think that would be a good insulation? Should we insulate the exterior as well? We also want to build a basement either under half or the whole structure, is that a good idea? Can it be done?
Thank you for your help with our questions. G-d bless you for your knowledge and consideration, CarolAnn
Owen Geiger (author) in reply to CarolAnn525Jan 11, 2012. 6:14 AM
I don't know of any earthbag houses in Minnesota, but then again most people don't publicize their projects. Earthbag and strawbale both fall under the Alternative Materials provision of the code. You'll need additional exterior insulation in Minnesota. Earthbag basements are still experimental. Using ICFs would likely prove more expedient and realistic for most.
CarolAnn525 in reply to Owen GeigerJan 11, 2012. 11:13 AM
Thak you Owen,
I will let my husband know and continue on with the resurch. I will keep you psted as we move forward. Go-d bless, CarolAnn
mstricker says: Nov 8, 2011. 12:47 PM
I have been researching earthbag houses in hopes of building my parents a new house on their land in Northwest Missouri. They need something well insulated as it can get quite cold in the winter and is very hot and humid in the summer. Our funds are extremely limited so I was thinking the rice hulls make the most sense for us economically but was wondering how much they would be affected by moisture. Not only is it quite humid but they are in the Missouri River flood plain and also get some tremendous thunderstorms. I was planning on trying to build the foundation up with concrete rubble and gravel filled sandbags for the first few feet to help minimize the flooding damage. I would love some advice and encouragement on this. Will rice hulls work in this wet climate and any suggestions on building up the foundation? All and any advice appreciated and welcomed!
Owen Geiger (author) in reply to mstrickerNov 8, 2011. 4:59 PM
We know of at least one earthbag house in Thailand made with bags of rice hulls. I was just in contact with him and his house survived the first rainy season. They get lots of rain and so what you're proposing is possible. I wouldn't risk it on a large, expensive home, but it should be fine on something small and simple. You have to be super careful the rice hulls don't get wet during construction, from roof leaks, leaks around windows, etc. It's taking a risk for sure. Maybe build a post and beam frame, finish the roof with wide roof overhangs and install the rice hulls later.
I would use broken rubble in a rubble trench and then fill lower bags with crushed gravel up to about window sill height.
chrisandamanda says: Sep 25, 2011. 10:06 AM
Just a question but could you not use a Styrofoam sheet and attach it to the walls at all? Kind of like they do to a house that they are re-plastering?
Owen Geiger (author) in reply to chrisandamandaSep 25, 2011. 4:41 PM
Sure, that's the easiest way, but styrofoam is not good for the environment so I'm suggesting alternatives.
chrisandamanda in reply to Owen GeigerSep 25, 2011. 5:11 PM
I mean polystyrene I know that they can come in sheets. I love this idea. I live in Canada would this style of building work in a cold wet climate?
Owen Geiger (author) in reply to chrisandamandaSep 25, 2011. 6:51 PM
Polystyrene is the same as Styrofoam. I show recycled polystyrene peanuts in this section view: http://earthbagbuilding.wordpress.com/2011/09/15/solar-pit-house-building-details/
So yes, this can work in Canada with a moisture barrier to protect it.
mike poind says: Jul 14, 2011. 9:23 AM
so what is the R factor of a earthbag wall/home useing soil & clay as bag fill
Owen Geiger (author) in reply to mike poindJul 14, 2011. 5:44 PM
A quick google check says .25 per inch. Typical earthbag walls once plastered are 18", so 18x.25=4.5 R-value. This is suitable for mild climates (where adobe houses are typically built). You can use insulated fill material in colder climates or add insulation on the outside.
armynavy17 says: Feb 18, 2011. 2:36 PM
Good instructable. I'm curious though, on your website you have plans for multistory homes, yet you don't explain how one would do the floor of one of these. That's my question, how would one build the floor of the second level?
calgarc in reply to armynavy17May 4, 2011. 12:36 PM
you can do a loft type setup by having a portion of the second floor usable and use pillars to hold it up.
Owen Geiger (author) in reply to calgarcMay 4, 2011. 5:25 PM
Yes, lofts are a great way to add extra space inexpensively. You may not need pillars, depending on the span. I particularly like sleeping lofts because they're warm and cozy at night.
Owen Geiger (author) in reply to armynavy17Feb 18, 2011. 4:43 PM
There are numerous possibilities for building second stories. You could use the Precision Structural Engineering, Inc. method. You could use post and beam or confined earthbag. You could build a lightweight second story. Use the search engine on our blog. Every topic is covered.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
