How to Build an N.F.T. Hydroponics System
25,871
370
23
Posted in WorkshopHydroponics
Introduction: How to Build an N.F.T. Hydroponics System
About: The act of invention is simply intelligent laziness
Have you ever had trouble with taking care of a soil garden or thought it was too much maintenance? If so, hydroponics will be great for you. Even if you do like soil gardening, hydroponics provides a fun variety from traditional gardening and in most cases provides higher yield on a shorter amount of time. On top of all of that, you can grow plants inside, meaning you can grow and harvest them 24/7 365 days a year!
In my very first instructable (yay!), I will show you how to make a particular type of hydroponic system called NFT (nutrient film technique) that takes a water-nutrient mix from a reservoir, takes it into the channel where it flows through giving nutrients to the growing plants and goes back into the reservoir. This means that this is a recycling system which means that virtually no water is wasted and you don't have to put harmful chemicals from the nutrients into the environment. This certain hydroponic system is hands free until you want to harvest, meaning that you don't need to do things that you normally would have to in conventional soil gardening like watering, weeding, or worrying about pest control!
Step 1: Materials & Supplies
Materials:
1. 4" wide PVC pipe (in this case, I cut the pipe down to 1' 8" in length, but you could hypothetically have it up to 15' in length)
2. A grow light
3. Two pieces of 2 by 4s
4. 6' of 3/4" wide black vinyl tubing (two pieces. One 10" and the other 4'6")
5. A storage bin
6. 3" plastic netted pots
7. Submersible pump (159 gph)
8. Ionic Grow: the ultimate solution (liquid hydroponic nutrients)
9. Some type of growing medium (perlite, growool, expanded clay balls, etc)
10. Two 5" PVC flat caps
Supplies:
1. 3/4" drill bit
2. 3" drill bit
3. 1" drill bit
4. Drill
Step 2: Building the Channel (PVC Pipe)
To build the channel of the system, you must first cut down the channel down to 1'8" (if you want to have the same design as mine, cut it to this length. I just found that this size fits best on the top of the storage bin). You must then drill 3" holes that are all equally spaced on the top (refer to picture 1). These will hold the pots in the channel. On the opposite side of the large holes, drill a 3/8" hole (refer to picture 2). This will be for draining the water within the channel. Next, drill another 3/8" hole near the middle of ONE of the PVC caps (refer to picture 3). This will be for the tube that gets the water into the channel from the reservoir. Finally, you will need the two pieces of wood and cut an upside down isosceles trapezoid near the top of the wood (refer to picture 4). This will hold the channel in place. You will also need to have one of the pieces have a more substantial indent to provide a slight slope of the channel for water to flow. To find out how much slope you will need you can use a 1:30 ratio, meaning that for every 30" of horizontal length there should be a 1" of vertical drop.
Step 3: Building the Reservoir (storage Bin)
To start, you will drill a 3/8" hole at the far end in the middle of the reservoir. This hole will connect to the hole at the opposite end of the large hole with the 10" piece of black vinyl tubing. You will then need to drill a 1" hole on the opposite side of the hole you just made but make it slightly more to the right. This will be for the power plug of the submersible pump About 4-5 inches above the 1" hole. This will be used for the vinyl tube that will be pumping the water into the channel.
For the configuration of holes, refer to the picture above.
Step 4: Putting It All Together
First off stick the 4'6" tube into the hole closest to the hole for the outlet. Put the 10" tube into the far end hole. Next, put the submersible pump onto the bottom of the reservoir and connect it to the longer piece of tubing so it sits flat on the bottom of the bin. Run the outlet through the 1" hole and plug it in once your ready to. Next place the more indented piece of wood near the far end of the side with only one hole and then place the other piece directly opposite to it (the idea is that it slopes downward to the hole that is for drainage). After that, you can add the channel. You need to connect to 10" tub to the hole at the bottom of the PVC and put the longer tube into the PVC end cap. You should make sure that the height of the tube inside of channel is at the same height as the very bottom of the pots when they rest in the holes (this is to ensure that the water level is just barely touching the roots so they don't drown). You are now ready to add the nutrient-water mix into the reservoir and power everything up. I added about 5 gallons of water and added the nutrients accordingly (there is usually instructions on how much nutrients you should add for every gallon of water, so look for that on the package of the nutrient mix you buy). Make sure to mix it up and then your ready to turn on the pump. You can now add the sprouts/seeds in the netted pots with the inert medium of your choosing. Once everything is setup, you can you put in the grow light above the plants. Make sure it's far enough away to not burn the plants, but close enough for the plants to carry out photosynthesis.
Step 5: Hydroponic-ing Tips
To become a hydroponics master, you will need to learn helpful tips and tricks to improve your crop yield:
1. If your operating the system outside, make sure that nothing is clear or opaque because sunlight can deactivate some ingredients in the solution.
2. You should add new nutrients about every 10 days
3. If you want faster, more effective growth you can add certain natural growth hormones like gibberellic acid to the crown of the plant (everything above the soil).
4. If want further information on NFT hydroponics, you can check out my video that I made that goes into further detail of the system I made. -> http://youtu.be/cbBFPOLHUO8
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    23 Comments
    I'm new to this idea, and my question is: how do you get the plant into the system? do you put the seeds in the pots? or do you buy seedlings?
    https://www.youtube.com/watch?v=GhFkR9GAGu0 rooting your clippings
    This is a great concept , I was looking for something to model after and this looks great and simple. 2 tubs was my first idea, but using pvc on the top gives it the ability to be more compact! WIll add wheels under mine.
    Wow...great idea with simple instructions. You put all the information needed that anyone with half a brain could utilize and build. I personally do not like over kill instructions that I have to constantly re-read to find next step. GOOD JOB!
    Reminds me of my English Literature Professor dumb as a stump but knew how to write in!
    I would like to suggest that your comment would have been better if you had just said "Good information.". Unless of course, you would like to improve the article.
    Best regards..
    Wish I had the time to try this as a starting point for a Hydroponics setup. Do you could use a fish tank as the reservoir? I'm assuming a good fish tank pump\filter system could send the water around the system. Wonder if the fish would like their growing neighbours...
    for aquaponics, You would however need some kind of a substrate for the bacteria and the fungi that convert the fish metabolites into feed for the plants. something that provides enough surface space for the microorganisms. like lava rock...
    This is known as aquaponics and yes, the fish would like them.
    The idea is that the fish produce nutrients which the plants consume. The fish benefit because without the plants the nutrients can build up to levels that are harmful to them.
    Ive been into hydroponics for years and the N.F.T. works best in rectangular pipe you get a much more even spread of the roots and more roots exposed to air. If you want really good growth your PH level is critical and for me expanded clay is the best medium as you can use it over and over but you have a good little set up. Happy growing
    I've never tried hydroponics, so I don't know Jack... well, except for Jack in the Box. (Only amusing and makes sense if you had one or have eaten at one... LOL). However, I'm a huge fan of landscaping and gardening, etc., so from my perspective, I thought the instructable gave me a great starting point... inexpensive, a video for further reference, and comments from folks to fill in some of the details or suggestions.
    As for the "contentious" comment: 1) Not everyone is a writer... even if the have a writing degree (yes, I have one and no, I don't work as a writer), and that includes many of the genius individuals that have brought amazing advances in science, medicine, etc., so keep writing your instructables just like you did (with lots of great explanation and images) and simply review it (reading aloud slowly works best imho) to see if it sounds easy to follow, makes sense, and provides all the details that we tend to forget when we're being brilliant and trying to put it on paper before we lose our train of thought; 2) the contentious comment would have flunked the grammar and punctuation sniff test... and thus the cliche addage comes to mind about casting bricks when living in glass houses.
    Yes, that was one serious run-on sentence, with a popular IM/SMS/Tweet acronym... but hey, I paid for my degree in writing, so I'm pretty sure, at that cost, I have a license to do those things! LOL
    GREAT JOB!
    My thoughts during the instructable: 1) Love the explanation and presence of the grade for the tube... same great info to consider if you're putting drains in your yard!; 2) Size of container for water and pump size "ratio" (applicable term, but maybe not exactly precise) to tube length... or number of plants... meaning, could you have replaced your 1'8" 3-plant tube with the 15' tube? 3) Are 3" holes and the spacing you chose specific to what you planted, or are they relatively generic, go-to for all plants? That popped up because as we all know, when gardening in soil, spacing is fairly significant for both root growth and plant size.
    Those are a few of the thoughts that crossed my mind.... so honestly, I did not proofread nor edit your writing.
    Proof that you were informative and that twitter and text limitations on number of characters have inspired a new "genre" of "creative" writing to the point that no one (outside of classwork) should be getting bent unless something is unreadable.
    Just my humble opinion, my friend!
    Hey man thanks for posting your project. It sux when people come in and get nasty instead of helping. First use a different light. If you have the money get a HPS lamp.If not get a bunch of those huge compact fluorescent lights that fit in regular sockets. They have like 2500 lumens each. The light u have now is terrible. They are hot and awful lumens. The fluorescents can come so close to the plants.
    I used baskets with soft foam rubber and had no problems
    He's using expanded clay.
    Growing medium is what you grow the plants in the two most common are pearlite and rock wool. There are more but these two are the easiest to use and easy to find at most garden shops and places like home depot and lows.
    Looks great have done similar but used a 12v solar panel and a constant voltage regulator and no battery so it ran as long as the sun shine and stopped when the sun went down I managed 3 crops in 1 season
    Great job and well written! Thanks for sharing.
