How to Build the Perfect Zombie Survival Kit... by mooman666
Step 2: What to wear...
Here's what to wear in a zombie apocalypse....
- Under Armor. It's light and will either keep you cool or keep you warm.
- Motocross/Paintball jersey. They are both a good long sleeve top that can breathe, or have room to add layers underneathe (depends on your climate)
- Soft elbow and knee pads. They dont hamper mobility and keep you comfy. Plus TRY biting through them.
- A solid pair of cargos. Light and have lots of storage space.
- A good headband. To keep the sweat out of your eyes.
- Waterproof hiking boots (broken in). You'll be on your feet a lot.
- Set of goggles that won't fog. Either snowboard, paintball or motocross will do.
- Bandana. to cover your nose and mouth. Things will get messy.
- Good set of gloves. Again motocross or paintball will do.
And keep in mind if it's cold out you'll need to dress/pack accordingly. Just keep in mind to cover up.
larmstrong2 says: Jan 16, 2013. 2:11 PM
i agree with a lot of that but i think a balclava would be better
barry960 says: Jul 28, 2011. 5:20 PM
If I were to choose an SKS, I'd have to have the modified extended capacity magazines. I mean, 5 shots, if you know zombie movies, is just nothing unless it's a 12 gauge or bigger. I'd also recomend a secondary firearm for just any scenario, a handgun of your choice, or a pistol grip shotgun if you choose a rifle as a primary weapon, or one of each preferably.
Remoah says: Jul 26, 2012. 11:19 AM
SKS holds 10 as standard, 20 with extended aftermarket, 30 if you get an SKK (accepts AK mags).
My bet would be SKK, since it can be top-fed like a regular SKS, you can keep replacement mags for those 'last ditch' scenarios where you really need a reload. Dealing with one or two walkers or the odd lurker, just top it up from loose ammo in the pockets or wherever.
barry960 says: Nov 19, 2012. 6:29 PM
Oops, pardon, 10. Don't have one myself, and barely have handled my brother's. I got an AK anyway, underfolding stock for compactness, and would rely on it for any SHTF situation for sure. A silencer would be great, but not an easy item for most people to get, I mean let's talk full automatic and RPGs too while we're at it. (although you could certainly go with make-shift substitutes with a little know-how in a pinch)
Emonster2399 says: Nov 18, 2012. 4:50 PM
i would also suggest a silencer since the zombies will be drawn to the noise. i would also add a bunch of things to the list and i would think everyone else would to.
larmstrong2 says: Jan 16, 2013. 2:12 PM
good point
DannytheGreat says: Jun 28, 2011. 12:11 PM
i recommend steel toed boots, even though theyre heavier theyre an improvised weapon
jonno488 says: Apr 9, 2012. 5:52 PM
they are also longer lasting and give more protection than sneakers:)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
