loading
Step 3: Pressure Can
Following your manufacturer's instructions, can the carp for 90 minutes at 15 lbs pressure. I can tell you how long to can it for, and the pressure, but you need to follow your manufacturer's instructions as far as how many cans you can do, and how much water to add.
Be careful.  I nearly went dry when I was canning, so be very careful, if you stop hearing the wobbler, you may have a problem on your hands.  You could have run out of water, or the release could be clogged, either way, remove from heat and consult your manual as to what to do next.  Remember you are working with a pressure vessel, which may blow up if not used properly.
So be careful, it isn't worth blowing up your kitchen for a batch of canned carp.
<p>Does this process work for other fishes or other meats?</p>
<p>It works with other fish with small bones, I am not sure about meats. </p>
About This Instructable
8,609views
9favorites
License:
Bio: I have a range of interest bordering on the insane. From blacksmithing to foraging, cooking to sewing, I have probably done it, read up on ... More »
More by handsonlife:Make a sling How to make the spice Sumac and Sumac lemon pepper How to make Sumac Verjuice
Add instructable to:
