How to Car-Camp in the Rain: 11 Lifehacks
362,778
811
95
Published
Introduction: How to Car-Camp in the Rain: 11 Lifehacks
Here are a few simple tricks for car-camping in the rain. Most of these may be well-known to people who camp in the wet... but for those new to it, here are some little lifehacks we've put to use in various state parks here in the northwest.
Step 1: Tip 1: Raise That Tarp
When car-camping in the Pacific northwest, the first order of business is often to get the tarp in place.
To start, tie a rope around a tree near your eating area. A good knot to use is a bowline knot ("the rabbit comes out of the hole..."). You can also use a "no-knot," in which you simply wrap the rope a few times around the tree; friction will keep the rope in place.
Keep the tarp high enough to allow good light in. Use a forked stick, or a "chuck-it" ball-thrower if you have one, to coax that rope higher up the tree.
Step 2: Tip 2: Forget the Grommets
Don't bother with those little corner holes in your tarp; they're not strong enough to handle the tension you'll need for a good rain-shedding cover.
Instead, take a tennis ball or a similar-sized rock and wrap it into the corner of the tarp. Tie off with a few wraps of the rope and some half-hitches.
Step 3: Tip 3: Rig a Drying Line Under the Tarp
If you have a long enough rope, run it diagonally across the tarp and tie it to another tennis ball in the opposite corner. This helps prevent tarp sag, and can also serve as a drying line for light items.
Step 4: Tip 4: Cinch Up the Tarp Tightly Using a Trucker's Hitch
You need to stretch the tarp tautly across the diagonal so that it sheds rain. A loose tarp will flap in the wind and collect puddles of water overhead.
To cinch the tarp tightly, wrap the rope around a tree and bring it back through a slip knot tied into the main line of the rope (the part running diagonally from the tennis ball). Pull the rope back from the slip knot. This technique, called a 'trucker's hitch,' almost doubles your leverage for pulling the tarp tight. Tie off the tightened rope with half-hitches.
Step 5: Tip 5: No Tree in the Right Spot? No Problem.
Again using rocks or tennis balls, tie off the remaining two tarp corners to nearby trees.
If no trees are in a good position to tie the tarp neatly, run an additional line between two trees and secure the rope to the line.
The tarp should now have two tight, flat planes that lie comfortably above your eating area, and that will readily shed rainwater.
Step 6: Tip 6: Tuning Up a Sagging Tarp
After a night of rain, you might have to cinch up any sags that have developed in the tarp.
You can undo and re-tie the ropes tied with trucker hitches. Or, if only a minor cinch-up is needed, take a strong stick or an extra tent stake and twist it between the two lines coming from your trucker hitch. A few spins of the stick will tighten up the tarp line. When done, use a second light rope to tie off the stick to the tightened rope.
Step 7: Tip 7: Use Outdoor Carpeting Outside Your Tent Door
A small rectangle of outdoor carpeting takes very little room to bring along, and makes for a nice staging area for removing muddy footwear before entering the tent. It really helps to keep the mud and dirt outside where it belongs.
Step 8: Tip 8: the Most Important Tent Peg of All
Almost every time we've gotten lazy and skipped the installing of tent pegs, we've regretted it. It's disheartening to see your tent cartwheel away in a gust of wind.
While you're at it, don't forget the handiest tent peg of all: at the bottom center of your door. With this peg in place, you can work the tent zipper one-handed.
Step 9: Tip 9: Keep Your Footwear Dry at Night
If you bring your shoes into the tent at night, set them on plastic bags to make clean-up of the tent floor easier.
You can also keep them outside, under the tent fly. Just be sure to turn the shoes sideways or upside down so that a night-time shower doesn't soak them.
Step 10: Tip 10: a Clean, Dry Place for Food and Utensils
Most state parks have heavy grills that can hinge over the campfire. We never use these for grilling; the height is not adjustable and the cleanliness of the grates is suspect.
Instead, swing them out of the campfire, and slide some flat kindling in between the grates to make a simple holder for your cooking tools. Works great as a cooling area for corn on the cob, too.
Step 11: Tip 11: Rig Up a Firewood Holder
Add a few more strips of kindling to the campfire grate, to hold (and air out) your kindling pile or larger pieces of firewood.
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Game Life Contest
      Game Life Contest
    95 Discussions
    I've been camping for years, but learned several new tricks here! THANKS SO MUCH for sharing this wisdom. Can't wait to try them.
    You are welcome, and thank you very much for your kind comment! I always learn things from other campers... it's fun to stroll around the campground and see what techniques are being used in the various sites.
    This is so informative, you've covered all the scenarios with pegging down your tent for windy conditions to making sure your shoes are dry. Awesome job! Thank you so much for sharing :D
    Bajamo
    1 year ago
    Good ideas! What's your take on strapping on a tarp, like you have here (I always get rain puddles on mine) or buying one of those pop up tarps with 4 legs? My daughter said I need to be careful of the winds not blowing it away.
    Did you mean strapping one side to your tent, like a front porch? I've thought about doing that but (surprisingly) haven't needed to yet. I have seen posts where people have done that. Did you see further down about the variable-tension lines on the sloping corners? I think that might be safest and require least maintenance, not to mention that in a high wind, having the tarp attached to your tent just makes it more likely that it might pull the tent away too! This thread is making me think!
    I've rigged a large tarp over my tent (Coleman said it didn't need a tent-fly and they didn't have one for it) because the sun was very hot that week and I desperately needed to shade my tent. There were trees to the west of my site (but buggy), so I set the tarp over the tent and slanted down on the east side, over/along the tent tie-down lines with a slight gap between the tarp and tent provided by the frame (I only had the pegs that came with the tent). I wished the gap was bigger to allow for more breeze/better dissipation of the heat. I learned from this experience that there's no such thing as too much rope! Or too many pegs, which also would've helped to enlarge the gap. Live and learn!
    Also, a decent pop-up canopy should come with pegs and tie-down lines, my Ozark Trail one did, it even has a little wind vent in the peak. But if you're solo camping, it's a pain to put up on your own, the tarp might be easier.
    The diagonal corners of the tarp should be highest on the tree, with the other two corners lower. Make sure your lines are tight by using knots that can be cinched to tighten them up.
    Great stuff.... but one more thing for tarping: Use webbing around the trees with a biner for the cord to avoid damaging the bark when cinching. Be kind to the trees at campsites or they will die leaving you an ugly campsite. Thanks for the great tips!
    I like the tennis ball or rock trick. Now why didnt I think of that? LOL
    I used a rock this year camping, it worked wonderfully!
    Okok
    1 year ago
    We kept adding more and more "shade-inducing-artifacts" to our eating area last week, and even applied some of the tricks seen here, but I think the next time it will be better... See the sagging of the covered area after a light summer storm in Spain!
    I got some small door matts cheap at Grocery outlet for this purpose. The size makes it easy to fold over once and store under feet in the backseat of our sedan. Also, I found some rag rugs to put inside the tent. We drew lines of silicone glue along the back of them to reduce slipping.
    (burning man survivor)
    - I like the tennis ball idea(rocks will work, too. Plastic tarp clips are handy for attaching to a tarp at any point on the edge.
    - Housewrap makes a good cheap tent ground cloth(cut smaller than the tent, of course.) Just cut it a few inches smaller and lay it down before pitching the tent. It doesn't need to be tied.
    - Some say you should tie your tarps and tents with heavy rope. I prefer to use small string. Storm blows up, breaks string. Tent falls down. Tie on new string and put it all back up. When a big windstorm or thunderstorm blows in, SOMETHING will break!
    trgz
    1 year ago
    that tennis ball trick is brilliant - it almost needs an instructable to itself
    nice tips,makes caping much easier.
    Great tips for the tarp! I've been camping in rain for years, and always curse at my sagging tarp. This should take my cursing down a few notches. :)
    We don't have a dog and usually only have a tennis ball around if I find one in the woods or a park when I'm out geocaching. However, I usually have on sneakers or hiking boots. I put a clean grocery bag on the end of my 28-year-old hiking stick (to protect the inside of my sneaker), stick my hiking stick into the sneaker, and use that to push up my tarp for drainage.
    As an Alaskan Scouter (adult volunteer Boy Scout leader), this is my 43rd consecutive year of Scouting, and I grew up in the NY Catskills camping all the time as a kid. Our youngest son made Eagle in a very active troop that camped every month year-round (the coldest I've camped with my Scouts is 39 below). I love camping with them, and the adult camaraderie around a bedtime campfire is awesome! (We don't carry alcohol on Scout trips; campfire coffee is the only coffee I usually drink.) If a troop is not going out when I want to, I camp alone (which always unsettles my non-camping husband).
    Dressing for the weather, using layers of clothing, and avoiding cotton ("Cotton kills") are all helpful tips. I remind my Scouts to change ALL clothing at bedtime - socks, underwear, the works. There are many youtube videos with all kinds of camping and sleeping safe and warm tips, and more recipes than you could ever use.
    Thank you for this well-organized camping 'ible. The pictures and camping tips combine for great instruction. Good job!
    prain1
    1 year ago
    Very informative, like the tennis ball trick.
    My bf in Hawaii and I earned the title Campers in the Rain, and we did many of the suggestions and camped under tarps with no tents and lots of mosquitoes even. What were we thinking? Wonderful presentation and wonderful comments all. Thanx so much for the trip I took down memory lane. Now I live a similar rustic lifestyle in rural FL farmland so no longer have to camp to get in Nature!
    Another good idea is to face your tent towards the Dining fly so you can leave and enter without getting wet
