3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Carve a Jack-o-lantern
  • last photo ←
To carve a Jack-o-Lantern you will need the following materials
1 Pumpkin
1 Medium Serving Spoon
1 Medium Knife
1 Small Knife
Newspaper
Medium bowl
1 Dry Erase Marker
1 Candle
1 lighter
Step 1Preparing for carving
Cover your working surface with the newspaper.
17 comments
Oct 24, 2007. 5:54 PMJakeTobak says:
I got a couple things to add that I've done in the past. 1.) If the light is strong enough you can use wood carving tools to scrape away at the skin of the pumpkin so it's not cut through but light still gets out a bit, kind of like putting a flash light inside your mouth and your cheeks glow. That way you can have a 2-tone design. 2.) I used an anti-fungal spray to prevent stuff from growing inside the pumpkin, preserving it a little longer. I used some jock-itch spray (was using it for my feet before) and I think it worked well. Just be careful if its combustible and you're using a candle.
Oct 28, 2010. 8:52 AMkendrickbooker says:
cool boy
Apr 4, 2008. 1:56 PMdontno says:
I use a saber saw to carve out pumpkins cuts down on carving time. Done in10 minutes.
Oct 21, 2009. 8:55 AMThaNorwegianDude says:
yeah... but isnt that taking away the point? i mean half the fun is to carve the thing out
Sep 24, 2009. 11:57 AMRevel says:
you should cut a try angle in the lid so its easy to find the way it gos in
Oct 30, 2007. 6:09 PMenglish_sensei says:
1.any tips on how to keep the lid from burning after a few hours? 2.how about making it last longer without falling apart? 3.has anyone tried drying the pumpkin out in the sun or anything else? as for no.1, initially, it seems OK, as the inside is still moist, but as it dries out, it could become dangerous. i would prefer to use a candle for maximum effect. any suggestions?
Oct 29, 2008. 9:54 AMBongmaster says:
i heard rubbing a bit or vasoline into the inside, and the cut parts, helps it last a bit longer.
Jul 12, 2008. 5:58 PMdontno says:
I use Chem Lights. Snap it and toss it into the pumpkin. No heat is generated.
Oct 14, 2008. 8:11 PMcarrierpilot1357 says:
you should go look for an electric pumpkin carver. They make it a lot easier.
Jul 12, 2008. 5:27 PMSt0ney says:
Nice Tut ! St0ney stoneykins.com
Oct 31, 2007. 3:57 AMLunaLovegood says:
The Instructable would be good for beginners, but I'm sort of advanced at this so I got bored. --Luna Lovegood--
Oct 25, 2007. 5:09 PMX_D_3_M_1 says:
i got that lighter. for 25 cents.
Oct 25, 2007. 10:02 AMsnipegoat says:
I always add a little rectangular nub popping off the stem when cutting out the top ,so its easier to find where to put it instead of just twisting it for an hour till it fits or just placing it lazily on top so it sticks out (it drives me crazy) you know exactly where it goes like .....stem---- ( )=
do you see what i mean.
Oct 25, 2007. 11:29 AMKiteman says:
Like a key? You could also cut the lid rectangular or triangular for the same reason.
Oct 25, 2007. 11:25 AMhavanacus says:
I'd like to add that those seeds make a delicious baked snake with a little salt...
Oct 25, 2007. 3:16 AMKiteman says:
A classic Make, well-described.
A couple of safety points from personal experience -
  • The lid can get very hot, mind your fingers.
  • Blow the candle out, or let it go out by itself - dripping water through the lid into a molten tea-light causes a similar response to water into a chip-pan fire. Kitewife was lucky to just lose her fringe.
Oct 24, 2007. 5:37 PMJohn Smith says:
Oh, good instructable.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:buhlers
