Introduction: How to Chamfer a Nut in Fusion 360
Picture of How to Chamfer a Nut in Fusion 360
Anyone wanting to chamfer the Hexgon Corners of a Nut in Fusion 360 will find, it cannot be done the conventional way ... after extruding the Hexagon. Because Fusion 360 is parametric modelling software it needs to be tackled as a Solid. After a lot of searching, I was able to work it out.
It is assumed that the user is familiar with the basics of Fusion 360
Step 1: Sketch Circle and Extrude Blank & Chamfer
Picture of Sketch Circle and Extrude Blank & Chamfer
Sketch a circle with diameter dimensioned the same as the across corner measurement of the nut. In the example it is 21mm for a M12x 1.75 Nut. The A/F (Across Flat) of the Hexagon is 17mm.
Extrude the circle to the thickness of the Nut eg.12.
Select the corners on both sides and Chamfer.
Step 2: Create Thread
Picture of Create Thread
Sketch a Circle in the centre of the Chamfered Blank.
Use Create, Thread and select the Sketched circle.
Enter the Thread Designation in the Thread pane.
Make sure the Modeled Box is ticked. (For 3D Printing, if the box is not ticked the STL files does not contain the thread and it will not be printed.)
Step 3: Sketch the Hexagon & Circumscribed Circle
Picture of Sketch the Hexagon & Circumscribed Circle
Select the original face and use Sketch, Centre Diameter Circle to sketch a circle the same diameter as the extruded blank. (This is required for creating the 6 segments, that will be extruded in the final step)
Use Sketch, Circumscribed Polygon to draw the Hexagon.
Make sure that the Corners snap to the Circle.
Step 4: Extrude the Hexagon Segments
Picture of Extrude the Hexagon Segments
Use Create to Extrude the Hexagon.
Select the 6 Segments around the blank and Extrude. See the Image above.
(Manipulate the Isometric model to assist in selecting all 6 segments)
About This Instructable
676views
13favorites
License:
Bio: Have built my own PCs and enjoy tinkering. Also very interested in 3D printing. Using Fusion 360 to design parts to run on my Flsun ... More »
More by Dolon12:How to Chamfer a Nut in Fusion 360Fast, Easy and Almost No Cost Power Tool StorageHow to Program an ATtiny 85 Digispark
Add instructable to:
