How to Change Battery on Daniel Wellington Watch?
17,093
7
Published
Introduction: How to Change Battery on Daniel Wellington Watch?
Follow these easy steps to change the battery on Daniel Wellington watch and SAVE SOME MONEY!
Step 1: What'll You Need:
1,4mm flat screwdriver and a cotton swab
Step 2: Remove the Screws
Use the screwdriver to remove the screws. Be careful if the screws are tight.
Step 3: Clean the Parts
Clean the parts with a cotton swab if they are dirty but be careful no to damage the watches inner parts.
Step 4: Remove the Battery
Remove the old battery. Note: it might be difficult at first but be patient when removing it and and be careful with the screwdriver so you won't brake the watches mechanism.
Step 5: Replace the Battery
Replace the battery with a new one.
Battery type: SR616SW: http://ebay.to/2ep4te8
Step 6: Assembling
Put the cover back and tighten the screws
Step 7: Set the Time
Set the time and ENJOY your DW watch!
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    1 Questions
    Thank you for the information!
    This batery type can be used in all DW watches?
    Hi denisam5! This battery type is quite common so I would say yes. But you can easily check that by opening your watch and checking the type there. ;)
