1.Car Jack
2. Socket Wrench
3. Spare Tire
4. Flat Surface
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
the same shall be done with the flat tire when you are attaching the new tire.
Step 2: Losen them, but do not unscrew them. A quarter turn maximum. You car is still resting on the wheel!
Step 3: Check with your car's manual where to put the jack. The structure of your car might be damaged if you choose the wrong spot. Often, the correct positions are marked on the manufacturers jacks (although they often are a PITA to use).
Step 6/7: Do not tighten the nuts clockwise (or counter clockwise). Move across the centre. I.e. if you have 4 screws (and think them numbered clockwise), go 1-3-2-4, if you have 5 nuts (and think them numbered clockwise) go 1-3-5-2-4.
Use a torque wrench.
Before you start:
If the terrain is not flat - put a wedge under the opposite wheel.
Engage the hand brake - this will stop rear wheel from spinning.
If you have a manual gear box and change a front tire: put the first gear in - this will stop the front wheel from spinning. (There is a tiny, unfeasible, remote option that you might start the car by spinning a front wheel, so remove the key from the car and put it into your pocket. Problem solved.) I have no experience with automatic gear boxes, sorry.
After changing a tire/all tires drive to/stop at the next fuel station and check the pressure. It may have lost some air after some months unused - i.e. the pressure will be too low.
