How to Change the Name of HC-06 Bluetooth Module
8,735
26
Posted in TechnologyArduino
Introduction: How to Change the Name of HC-06 Bluetooth Module
Many of the people search how to change the HC-06 bluetooth name which you see on air.
While this is well described in other Instructables, it is written only as a step. It was hard for me to find it. Therefore I've decided to make it as a separate Instructables. Eventually later I will add other steps how to change the HC-06 name in different way (through Arduino, by Bluetooth, etc).
Step 1: How to Program by Using TTL Programmer
What is needed?
1x USB to TTL microcontroller programmer
How to connect the Programmer?
VCC to VCC
GND to GND
RXD to TX
TXD to RX
Lets get started
1. connect the USB TTL programmer to the HC-06
2. plug in the USB and start the Arduino EID
3. open the serial monitor, adjust the speed if needed
4. type "AT" without quotes. You should see a respond in the serial monitor saying "OK"
5. type "AT+NAMExyz" where "xyz" is the desired name of the HC-06
6. type "AT+PIN1234" where "1234" is your desired pin. The response should be OKsetPIN
More detailed instuctions and comparison HC-06 and HC-05 is attached.
Notes: thanks to other people who did those great papers (Erich Styger) and instructables (nick: vandenbrande)
Step 2: Connect and Program Arduino As a Serial Port-forwarder for HC-06
By the tiny script it is possible, the Arduino will become a transmitter of your Serial Monitor and what you are typing will be sent to HC-06 Bluetooth.
Connection HC-06 (as usual), but:
HC-06 <-> Arduino
TX to D2
RX to D3
Write and upload small script like attached...
Upload script to Arduino, switch it off
Connect HC-06 to D2 and D3
Switch on Arduino, open Serial Monitor
you can type AT commands, those will be retransmitted to HC-06
Notes: it should work for HC-05 and HC-12 as well, but I did not try it yet.
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    3 Comments
    The instructions for the Arduino board worked like a charm, thank you. There's one thing: my HC-06 AT commands have a slightly different syntax, and maybe one of yours will, for changing the name, instead of:
    AT+NAMENewName
    I must add a colon before the name, like this:
    AT+NAME:NewName
    And so on for the rest of commands.
    worked just fine
    thank you
    i didnt try it yet
    how ever thank you very much
    greeting from egypt :)
