iImage Information
The process of changing oil in any vehicle is very similar. Some are harder than other because of where things are placed and the complexity of different types of motors. However in the 2009 dodge pickups it is a pretty straight forward process. Everything is pretty easy to access which makes for a quick job. This is broken so that even a first time oil changer can get the job with ease. I've included pictures of everything that will be needed including: new oil filter, seven quarts of motorcraft 5w20, funnel, floor jack, jack stands, 9/16 inch end wrench, oil filter wrench, and a oil drain pan.
Step 1Jack the truck up
iImage Information
Place the floor jack in the center of the front axle being sure that it is in a sturdy position. Jack the truck up far enough so that while you are underneath it is comfortable for you to work. Also be sure to place the jack perpendicular to the front end so that it will not interfere while removing the oil plug and the oil filter.
Well done on the guide, well written and informative etc.
Few things I'd advise though (work in a garage) Get the engine warm first, leave it about 15 mins though instead of 30. Then open the filler cap then drain. This is so the oil flows out better.
Also, I would not advise half filling with no oil filter on, oil filters are located in various places on different vehicles, so there could be a risk of major spillage.
I would NEVER use a spanner or a 12 point socket on the drain plug. This is because they round/square threads easily, I'd always use and advise 6 sided, flat hex shaped sockets.
Other then that, good guide. =)
