3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Change your Windshield Wipers
Windshield wipers are a necessary safety feature to any car. The problem is that they don't last forever - but rather need replacing every few years. The rubber blades dry out over time due to use and the sun. How can you tell that you need new wipers? They'll exhibit some of the following symptoms:
  • Streaking water
  • Squeaky
  • Leave a milky film when wiping
  • Any other reason it seems your wipers aren't performing well
Before buying new wipers, try simply wiping the dirt and hardened rubber off your blades with a wet rag. Sometimes you can get some more life out of them this way.
Step 1Buy your Blades
Buy your Blades
Before you go to buy them, make sure you know the exact model of your car. This includes the year, make, model, and further specifications such as, "type."
Go to your nearest auto body shop (or walmart) and give them your car's info. They will be able to look it up and tell you your options. There will many options for blades ranging from $5 to $25 each (you'll usually need to buy a different blade for each side). A good rule of thumb is to not buy the cheapest, or the most expensive ones. It's usually a good idea to replace both blades at once, if one has gone bad, the other can't be much better.
14 comments
May 16, 2009. 8:21 PMMadBricoleur says:
Does anyone know where to get used and worn out windshield wipers? I need the blades to make lockpicks and a kalimba. I was thinking, maybe at Jiffy Lube or some gas station with a car repair garage, but I'm not sure. Any help would be appreciated.
Feb 28, 2011. 4:32 AMJerryMopar says:
look also in the dumpsters of auto parts stores, custoemr will change them right at the store and dump them in the garbage
Jun 3, 2009. 4:17 PMzmatt says:
There are tons of them at auto parts stores, they overflow the garbage cans and are all around the dumpster.
May 17, 2009. 5:10 AMtercero says:
Something missing from this instructable I'd like to pass along from (sad) and practical experience. When you remove the blade, and have the arms standing up in a resting position waiting to install new blades, or even if you're just installing the blades and have the arms, which happen to be spring loaded, poised above the window. Place some padding at the termination where the arm/blade meets the window. 2 years ago I was changing the blades on my Saturn. While attempting to replace the blade, the spring loaded arm slipped out of my grasp. And smacked the window. As you can guess, the replacement cost of a new windshield is about $300 dollars. The nice solid metal arm made a perfect split up the center of my windshield. So. Use and old blanket or something large enough and soft enough to absorb the impact. Or have a really understanding insurance agent. I paid out of pocket.
Mar 10, 2010. 6:29 PMautomd says:
Thanks for sharing that practical experience. This may really help people who are into replacing their wipers and not end up breaking it.
May 18, 2009. 6:53 AMYerboogieman says:
The whole wipers, or just the blades?
May 18, 2009. 6:08 AMdevoted says:
I am a woman and this is useful of course:)))
May 17, 2009. 10:52 AMeudofair says:
Often wipers just lose their sharp edges so that they can no longer scrape the window clean. Taking fine sandpaper, placing it under the wiper, holding it so that both edges are in contact with the window and then sliding the sandpaper straight along the length of the wiper will sharpen it and make it work fine for some time. This assumes that the wiper is still flexible. Thanks for your ible!
May 17, 2009. 10:04 AMDanielfish says:
I'm not sure how standardised it is in the US, but in the UK there are many different methods of connecting your wipers, and most are incompatible with each other. It might be a good idea to take off your wiper and bring it into the store, if you're unsure and the assistants aren't being very helpful. For those in the UK, avoid Halfords, they will rip you off (not only do they charge way too much, but they will charge an extra £4 to fit a wiper, which takes all of twenty seconds).
May 17, 2009. 9:44 AMiPodGuy says:
Good i'ble!
May 16, 2009. 5:07 PMNachoMahma says:
. Good job.
May 16, 2009. 12:06 PMlemonie says:
Useful! (If you have a car)
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
151
Author:Weissensteinburg
I enjoy photography, horticulture and carpentry, and am almost always doing something relating to of those things. Feel free to send me a PM for whatever reason.
