A team of 6 students and one teacher put this project together, and we have decided to put it on Instructables in hopes of winning a laser cutter, or at least a t-shirt.
What follows, is a compilation of our presentation and my own personal notes. I hope you enjoy this Instructable as much as we did.
I'd also like to thank Limor Fried, creator of the MintyBoost circuit. It played an key role in our project.
Jeff Brookins
Divine Child InvenTeam Member
Remove these ads by
Signing UpStep 1Our original intention...
However, we had a problem. To quote my team mate Nick Ciarelli,
"At first we considered using a design similar to one of those shake-up flashlights and converting it so that a runner could strap it on for a run and have energy to charge their iPod or whatever device they use. The shake-up flashlight gets its energy from the interaction of the moving magnetic field of the magnet in the flashlight and the coil of wire wrapped around the tube the magnet slides through. The moving magnetic field causes electrons in the coil to move along the wire, creating an electric current. This current is then stored in a battery, which is then available to use for the flashlight bulb/LED. However, when we calculated how much energy we would be able to get from a run, we determined that it would take a 50-mile run to get enough energy to charge one AA battery. This was unreasonable so we changed our project to the bike system."
We then decided to use a bike-mounted system instead.
![Voltage Regulated [5v] Bicycle Dynamo Light & USB Charger](http://img.instructables.com/files/deriv/FKR/TCHO/GSEEJZIP/FKRTCHOGSEEJZIP.SQUARE.jpg)
Let me put it another way. I don't revel in wasting energy but it's not so much a concern when something is AC wall powered. When you are peddling on the other hand, and a design has multiple forms of loss, energy conservation is really good, worth the time to do it right.
The problem was they didn't look at how to get from point A to point B, point A being a human being producing linear movement of a wheel, and point B, producing the desired charge, then finding the best way to get there.
Instead, they reused a design not just suboptimal for the purpose but contraindicated for the input and output.
The way this is set up it would be far better to just strap a battery pack onto a bike to recharge something, or of course to use a proper bike generator, a switching supply circuit that accepts (uses) input over the voltage variations that result from a bike generator, and and output with current regulation and the associated charge control chip complimentary to the battery type being recharged.
I appreciate this is beyond the ability of someone starting out, but at the same time this is what is great about technology today that we have ready-made ICs to do things difficult or lengthly to do with discrete parts. It is good to experiment but it is also good to see when it is redundant work, that each part of the problem can be seen modularly as how to get from point A to point B and that today we have great custom ICs to do these jobs (since when broken down into units, none of the things being done are new electronically).
I think it's great if they had no hands-on experience, to learn from building something like this, BUT to put it out there for others as an example of how to get something done, it is a poor one.
I see that stepping down then stepping the voltage up again is a waste of energy. but when the power supply is so close to a LDO linear regulator I thought Providing consistent energy would be a problem.
You said "supercap is charged the voltage in the system rises and creates even more heat and loss with the linear regulator."
How is this so? I would like to learn from this experience.
I would like to learn how to make this as efficient as possible.
(I'm sorry about the short comment I wrote a big one but pressed cancel instead of post =( )
~Regards
Name101
Seriously, Thank you so much. =]
~Regards
Name101
Any help apprciated
thnx
jeffB considering you have used a ridiculous motor for this project i think the constructive criticism off kagetsujki is quite apt.
if you don't want people to sit on top off a mountain criticizing then don't give them such a big mountain
I bought the Cycle Charger from www.econvergence.net/cyclech.htm because it has a USB port. It works well and starts charging at pretty slow speeds - around 8 mph.
I use it primarily to charge my Blackberry for work.
Any help would be much appreciated.
Thanks in advance
At least a couple of companies (Shimano being one of them) make these alternators which are built into the hub of the front wheel. Mine puts out a fairly steady 6vac at speed, but is slews to 0v at stop.
Has anyone addressed this previously?
BCAP0150 - 150F ultra-capacitor Mouser Electronics - yay!
i'll post more later.
If the generator really puts out 6V, then a simple 5V output Low Drop-Out (LDO) regulator such as the Linear Technology LT1963A (http://www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1003,C1040,C1055,P1879) could be used to drive pin 1 of the USB directly. In this case about 83% of the generator power would make it to USB device. The USB device would charge twice as fast, and the circuit cost and complexity is significantly reduced.
If the generator typically puts out less than 5V under load, a 5V output Buck-Boost converter could be used. This would provide for further efficiency improvement. I don't feel the added complexity and cost is justified if the generator can put out more than 5V under load though.
