3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Chill a Beer in 5 Minutes or Less
video How to Chill a Beer in 5 Minutes or Less
Learn how to chill beers in a crunch. Kelly from HackCollege shows you 3 different methods.
For full episodes of the podcast and more, check out www.hackcollege.com
26 comments
Feb 17, 2012. 12:43 PMj77jbk says:
I mean this in a nice way but the guy reminds me of McLovin from Superbad!!!
Jan 30, 2009. 12:22 AMSolderguy says:
Can't you just stick it in the freezer for five minutes? I hope this works for Coca-Cola.
Feb 20, 2010. 4:59 PMzap1789 says:
 I'm pretty sure putting it in the freezer would not be as effective as submerging it in the ice/water/salt combination. The reason being the water would (I assume) be colder than the air inside a freezer, and because it's making direct contact with the water, it would cool faster.
Jun 3, 2010. 2:40 PMbrupbacher says:
There is a Mythbusters episode about this very topic.
They showed icewater to be faster than the freezer, and salt/ice/water to be the fastest.
As I learned in Chemistry about 15 years ago:  Salt water: lower boiling point, lower freezing point.
Dec 12, 2011. 5:03 AMjjohnsson says:
Nitpicking here, but the boiling point of saltwater is actually a little higher than fresh water. http://van.physics.illinois.edu/qa/listing.php?id=1457
But ofc, the usefull property in this case is the lowered freezing point. :)
Jan 30, 2010. 4:47 AMPhoghat says:
You have to time it closely other wise exploding beer cans
Jan 13, 2011. 3:18 PMdrbill says:
Back in 1971 up in Alaska 5 of us would drink a LOT of beer on our 2 days off.
We were in a USN fire department on ADAK, an island 800 miles out in the Aleutions.
We drank it soooo fast it was hard to get it cold fast enough.
We started bringing a 45 lb Co2 extinguisher back to the barracks with us.
A 10 second blast on a case of beer would make a small amount of ice in each can. Gave us enough time to chill the other 8 cases with snow!
Yure Tax Dollar At Work.
Feb 4, 2009. 1:43 PMthierry.kok says:
I know a faster method. use a fire extinguisher!
Aug 29, 2010. 7:43 AMjohnny3h says:
Yes, but you can't use the Dry Chemical tyoe, ONLY the CO2 [Compressed Carbon Dioxide gas type]. The release of pressure in activating the extinguisher creates a tremendous chilling effect. Be careful not to fast freeze your hands of skin [it only take seconds of contact with the blowing gas], and also be sure to use this technique ONLY in WELL VENTILATED AREAS, as CO2 can axphixiate [sp?] you very quickly.
Feb 17, 2009. 6:04 PMchristopherk239 says:
if you get some copper tubing in a coil and freeze it in ice. make sure both ends come out of the ice. place your glass under the tube and pour the beer in the top. when it gets to the bottom it will be ice cold .
Feb 23, 2010. 11:19 AMRmstrjim says:
Or, instead of flattening your beer: add a Bilge pump and shape the copper coil so  the beer container will fit inside, recirc ice water around zee beer.
Aug 23, 2009. 12:53 AM(seabear) says:
if u freeze some moonshine(i dont know anyone who does this. ahem) and take away the ice that is left then u have pure alcohol. DO NOT DRINK THIS ALCOHOL IS A POISON. seriously.
Jan 30, 2010. 4:45 AMPhoghat says:
Grasshopper, you are misled. If the moonshine is poisonous then the distillate will be also. If you can drink the shine you can drink the distillate.
My grandfather taught me this technique when I was just a grasshopper.During prohibition he would make his own hard cider from apple trees in our backyard. To make apple jack (brandy) he would freeze the cider and collect about the first 1/3 of melted liquid. Presto brandy.
When you can snatch the pebble from my hand you are ready
Jan 31, 2010. 2:55 AMgHjM3W5T20YCS4e30 says:
Phoghat & (seabear):
http://en.wikipedia.org/wiki/Applejack_(beverage)
Apr 6, 2009. 4:48 AMJohnJY says:
(first method is an incredible waste of drinking water! PLEASE don't do it,) NO we CAN'T waste water! It's not like it takes up more then 80%! SARCASM!
Jan 30, 2010. 4:46 AMPhoghat says:
Which is why the 3rd method is easiest and best. No water waste and the beer is cooled efficiently.
Apr 14, 2009. 12:11 AMD4VOBRO says:
Dude I live in the silly country called Australia, we're in a drought and most of us have learned the importance of saving water. Even though you may not be in a drought it still takes a lot of energy to purify water so.... um .... yeah i feel so lame
Jan 28, 2010. 4:36 AMOpsenica says:
liquid oxygen does it best... 2bad bottles break
Jul 18, 2009. 9:19 PMguy90 says:
Thanks for the upload- some good pointers here, and interesting to learn
Mar 19, 2009. 12:43 PMNyax says:
first method is an incredible waste of drinking water! PLEASE don't do it, use the freezer or something. As for the choice of beer, light?, why not water, its almost the same thing..
Aug 3, 2008. 8:21 AMfrontier says:
another method specially effective in the summer when the sun is baking down. wrap your can or bottle with the beverage in newspapers, so theres a thick layer around it. then pour cold water from the kitchen sink over the newspapers so they get soaked. then put it outside under the sun... its the same principal as just holding it under the running water.. BUT. the sun makes the water evaporate and leave the newspapers very fast, and enter the bottle/can. in a minute or so the beverage will have almost same temperature as the water had when you got it from the sink. the newspaper layer has to be thicker the more beverage is inside.. for a 1.5 liter bottle the newspaper layer need to be as thick as the bottle itself etc. works very well.
Jul 23, 2008. 10:47 AMBelcher1035 says:
Lay the can on its side in about 2 inches of icewater (lots of ice) with salt. Spin the can like a wheel with your hands (along the axis that is normally vertical). The drink will be cold in about a minute. It's basically the same method as the icewater bath, but spinning the can provides more effective cooling.
Jul 22, 2008. 6:31 PMTheScientist says:
doens't pouring it over ice make it lose some of the fizz? (i guess depending how fizzy it is...) a really good salt bath can get as low as -20ºC (don't know what that is in the archaic fahrenheit measure! :-P), we get our chemistry first years to make them. Tip for anyone at home making one: more salt is not always the answer! 50:50 ice/water (preferably with crushed ice) then a good handful per 1-2 liters of water ice mix (like shown in the video) should get nice and cold!
Jul 22, 2008. 5:50 AMmrmath says:
Mythbusters did this, and they found the ice/water/salt is the best method.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:hackcollege
