loading
How to Chill a Beer in 5 Minutes or Less
video How to Chill a Beer in 5 Minutes or Less
Learn how to chill beers in a crunch. Kelly from HackCollege shows you 3 different methods.
For full episodes of the podcast and more, check out www.hackcollege.com
probotchiller made it!12 days ago
The Probot Chiller was designed to solve this problem - it chills a 6-pack to ice cold in under 5 minutes. It's also portable, with dual USB chargers. Check out the Kickstarter here: www.probotchiller.com
RayK111 months ago
I just stick in in the freezer for about 20 minutes and bammm, never had anything explode, even when I forgotten about it, but then again I drink from glass, not cans.
Even when it completely frozen, I just put it back into the fridge and let it thaw naturally, it was still good.
Solderguy6 years ago
Can't you just stick it in the freezer for five minutes? I hope this works for Coca-Cola.
You have to time it closely other wise exploding beer cans
If you drink Hamm's beer the can may freeze but will never explode. The stuff freezes great and tastes good thawed.
 I'm pretty sure putting it in the freezer would not be as effective as submerging it in the ice/water/salt combination. The reason being the water would (I assume) be colder than the air inside a freezer, and because it's making direct contact with the water, it would cool faster.
There is a Mythbusters episode about this very topic.
They showed icewater to be faster than the freezer, and salt/ice/water to be the fastest.
As I learned in Chemistry about 15 years ago:  Salt water: lower boiling point, lower freezing point.
Nitpicking here, but the boiling point of saltwater is actually a little higher than fresh water. http://van.physics.illinois.edu/qa/listing.php?id=1457
But ofc, the usefull property in this case is the lowered freezing point. :)
look this :
How to Cool Beers Without a Fridge:
http://youtu.be/pVkapDyTSno
As you the second one, I can make a beer flat a lot easier than that haha.
HEY YOU3 years ago
I agree with Nyax, JohnJY et al  -  Clearly, you do not pay for water as cooling beer by running tap water down the drain is very wasteful. The Salt and ice water method is more water friendly.
Try buying your beer earlier.
Cheers
I supersize the third technique for parties, we use steel drums, ice blocks, about a kilo of salt and about 3 cases of beer.
I can swear by this technique really works. Also works for soda in cans and pet bottles.
FYI...this also works for beer kegs :D
j77jbk3 years ago
I mean this in a nice way but the guy reminds me of McLovin from Superbad!!!
Dr.Bill4 years ago
Back in 1971 up in Alaska 5 of us would drink a LOT of beer on our 2 days off.
We were in a USN fire department on ADAK, an island 800 miles out in the Aleutions.
We drank it soooo fast it was hard to get it cold fast enough.
We started bringing a 45 lb Co2 extinguisher back to the barracks with us.
A 10 second blast on a case of beer would make a small amount of ice in each can. Gave us enough time to chill the other 8 cases with snow!
Yure Tax Dollar At Work.
thierry.kok6 years ago
I know a faster method. use a fire extinguisher!
Yes, but you can't use the Dry Chemical tyoe, ONLY the CO2 [Compressed Carbon Dioxide gas type]. The release of pressure in activating the extinguisher creates a tremendous chilling effect. Be careful not to fast freeze your hands of skin [it only take seconds of contact with the blowing gas], and also be sure to use this technique ONLY in WELL VENTILATED AREAS, as CO2 can axphixiate [sp?] you very quickly.
if you get some copper tubing in a coil and freeze it in ice. make sure both ends come out of the ice. place your glass under the tube and pour the beer in the top. when it gets to the bottom it will be ice cold .
Or, instead of flattening your beer: add a Bilge pump and shape the copper coil so  the beer container will fit inside, recirc ice water around zee beer.
(seabear)5 years ago
if u freeze some moonshine(i dont know anyone who does this. ahem) and take away the ice that is left then u have pure alcohol. DO NOT DRINK THIS ALCOHOL IS A POISON. seriously.
Grasshopper, you are misled. If the moonshine is poisonous then the distillate will be also. If you can drink the shine you can drink the distillate.
My grandfather taught me this technique when I was just a grasshopper.During prohibition he would make his own hard cider from apple trees in our backyard. To make apple jack (brandy) he would freeze the cider and collect about the first 1/3 of melted liquid. Presto brandy.
When you can snatch the pebble from my hand you are ready
Phoghat & (seabear):
http://en.wikipedia.org/wiki/Applejack_(beverage)
JohnJY6 years ago
(first method is an incredible waste of drinking water! PLEASE don't do it,) NO we CAN'T waste water! It's not like it takes up more then 80%! SARCASM!
Phoghat JohnJY5 years ago
Which is why the 3rd method is easiest and best. No water waste and the beer is cooled efficiently.
D4VOBRO JohnJY6 years ago
Dude I live in the silly country called Australia, we're in a drought and most of us have learned the importance of saving water. Even though you may not be in a drought it still takes a lot of energy to purify water so.... um .... yeah i feel so lame
Opsenica5 years ago
liquid oxygen does it best... 2bad bottles break
guy906 years ago
Thanks for the upload- some good pointers here, and interesting to learn
Nyax6 years ago
first method is an incredible waste of drinking water! PLEASE don't do it, use the freezer or something. As for the choice of beer, light?, why not water, its almost the same thing..
frontier7 years ago
another method specially effective in the summer when the sun is baking down. wrap your can or bottle with the beverage in newspapers, so theres a thick layer around it. then pour cold water from the kitchen sink over the newspapers so they get soaked. then put it outside under the sun... its the same principal as just holding it under the running water.. BUT. the sun makes the water evaporate and leave the newspapers very fast, and enter the bottle/can. in a minute or so the beverage will have almost same temperature as the water had when you got it from the sink. the newspaper layer has to be thicker the more beverage is inside.. for a 1.5 liter bottle the newspaper layer need to be as thick as the bottle itself etc. works very well.
Belcher10357 years ago
Lay the can on its side in about 2 inches of icewater (lots of ice) with salt. Spin the can like a wheel with your hands (along the axis that is normally vertical). The drink will be cold in about a minute. It's basically the same method as the icewater bath, but spinning the can provides more effective cooling.
doens't pouring it over ice make it lose some of the fizz? (i guess depending how fizzy it is...) a really good salt bath can get as low as -20ºC (don't know what that is in the archaic fahrenheit measure! :-P), we get our chemistry first years to make them. Tip for anyone at home making one: more salt is not always the answer! 50:50 ice/water (preferably with crushed ice) then a good handful per 1-2 liters of water ice mix (like shown in the video) should get nice and cold!
hackcollege (author)  TheScientist7 years ago
My younger brother also pointed out that--if you can get it--road salt will cool things much better than your run-of-the-mill table salt: "Use road salt (Calcium Chloride, CaCl2) instead of table salt if you really want to cool something off quickly. You get more ions, which leads to an even lower freezing temperature of water. Just thought you might want to know." ~Kelly
hackcollege (author) 7 years ago
Damn! I guess we don't feel so bad if Mythbusters already got the scoop on us. I would have expected them to use liquid nitrogen or something crazy like that :)
mrmath7 years ago
Mythbusters did this, and they found the ice/water/salt is the best method.
