Introduction: How to Choose the Resin That Is Right for Your Plastic Injection Molded Part
There are a number of polymer compounds available for the injection molding industry, and this number seems to be continuously going up. Because of this, plastics have been being used more often now than they have ever been used before. These products are continuously being praised for creating strong products that last a long time. When you combine these factors with the benefits of corrosion resistance and the overall aesthetic appeal that plastic materials provide, then you will understand why they seem to be at the front and center of many manufacturing components. These materials are highly versatile, and this combined with their strength and weight make them perfect for use across a number of different industries.
With the high number or polymers and compounds available, choosing the best resin for your specific purposes can be difficult. The key to making the right decision is to understand the performance requirements that your part is going to have to meet. Luckily, there are a number of plastic injection molding resources readily available for use. Here are some things that you should consider as you try and select the resin for your product.
First, you need to think about what you want your final part to look like. Keep in mind the different type of texture you want it to have, the amount of transparency you require the part to contain, and the color you want the part to be. Next, think about how strong or flexible you want the overall part to be. Think about what type of resistance the part is going to need. Is the part going to be exposed to a lot of harsh environmental conditions? Will it be exposed to a number of chemicals? This is absolutely critical as you decide which type of resin you want to use. Next, think about the requirements your part is going to need in order to meet different standards. Finally, consider how long the part’s life expectancy should be. In other words, consider how long you want the part to last before it needs to be replaced.
When you are able to think through these factors and then select the resin, what you have done is thought about how you are going to be using the product. So, to make it simple, you should consider how the product is going to be used and everything surrounding that use before you select the type of resin to use. When you provide these details to your supplier, you are providing them with the information they need in order to tell you which resins will work best for the application in which you are going to be using your part. Some companies will even be able to give you some alternative choices based on the price of the parts and the availability of resins. You want to make sure that you and your manufacturer are working together in choosing the resin for your part.
