How to Choose the Right Survival Knife
 by AntMan232
This is my guide for how to choose the right survival knife. This is by no means a definitive list, because it depends on your personal tastes and the situations you are likely to be in, but I hope to tell you some of the main features you should consider for a general purpose blade.
if there is anything incorrect in this instructable, please let me know.
Also, these pictures are from google images to illustrate my points.
Step 1: The Law
In the UK, the law is fairly tight. I am not going to go too in depth about it, but my source of knowledge is here if you want to check up on it, or get some examples.  In general:
You may not carry a knife with more than 3" of cutting edge, and it may not lock open. Butterfly knives, flick knives, or other assisted opening knives are also banned; if you are caught with one in public, you will end up in jail.
Knives over this length may not be carried without good reason. The exception to this is :
1. Knives carried for work
2. Knives carried for religious reasons
3. Knives carried as part of national dress
As for what a public place is:
The Prevention of Crime Act 1953 section 1(4) provides that;
'a public place includes any highway and any other premises to which the public have or are permitted to have access, whether on payment or otherwise'
This also includes your car (even if it is locked).
Step 2: Film knives
Before I start, DO NOT be tempted by knives you see on TV and in films, such as Rambo. This is almost always the least practical knife you can have. it is much to big to be used comfortably and for delicate jobs. It is also the wrong type of tool for bigger jobs.
Moan over..!!
Step 3: Parts of a Knife
I think the picture below just about covers it. There may also be a pommel, or butt cap at the bottom of the handle, and a guard at the bottom of the blade. There might also be a lanyard hole near the end of the handle.
Step 4: Type of Knife
For day to day jobs, a small folding pocket knife will suffice, with or without a lock (depending on where you are/the common uses). For general bushcraft and survival, a fixed knife is best, as a hinge provides a weak point. I will be concentrating on fixed knives in this instructable.
For use in the jungle, i would recommend taking a large machete or axe as well, to cut your way through dense undergrowth.
Step 5: Size
For the length of the blade, I find between 4" and 6" is the ideal length, short enough to get control for finer jobs, such as carving, and large enough for heavier jobs.
Step 6: Tang
The tang is the piece of metal attached to the blade that runs inside the handle. The top tang is a a hidden partial tang or push tang. This may be useful if there is a hollow handle with a survival kit in it (a feature I would STRONGLY recommend you do not have, due to the loss of strength). The middle blade has a hidden rat's tail or stick tang. It extends the length of the handle and the handle is pressed or threaded on to it. The bottom blade has a full tang, which conforms to the shape of the handle.
Having a partial tang may not be a sign of weakness, because it all depends on craftsmanship, but I would recommend getting a knife with a full tang or rat's tail tang. This means that even if your handle breaks, you have something to wrap a cloth around or use instead.
Step 7: Knife Edge Grinds
There are many different grinds, but there are 6 main ones.
1. Hollow grind : This has a very sharp edge, and will cut through things very easily, but will not hold its edge well with use.
2. Flat grind :       The blade tapers from the spine to the edge on both sides.
3. Saber grind :  Saber grinds hold the edge well, but do not cut as easily as a hollow grind. it is similar to 2, but it starts further down the blade.
4. Chisel grind : As like a chisel (hence the name), only one side is ground.
5. Double bevel or compound bevel : The blade is thinner just behind the edge, which improves cutting ability. The actual edge, however, has a wider angle, so lasts longer, but does not cut as well.
6. Convex grind: This is the opposite of a hollow grind. There is a lot of material behind the edge, so it holds an edge well, and is fairly sharp. it is often used on axes, and tools for heavy use and chopping.
For a survival knife, I would recommend a saber grind or compound bevel, as these are easiest to sharpen without specialist tools, and hold their edge well.
Step 8: Blade Shape
As you can see, there are many different shapes. I am going to concentrate on the ones I would want on a general purpose knife.
1 Clip Point: The clip point blade has a fine tip, so is good for digging and picking. You can also sharpen the curved section above it, to make a lethal hunting weapon.
2. Spear point: A spear point or drop point is the standard blade shape used in penknives. it has a fair amount of material, so is very durable, and is good for cutting. It is not quite so good for delicate tip work, but is still a very useful blade shape.
I can't tell you which one is best, it all depends on what you intend to do with the knife. You would use all of the below shapes for different purposes, so think about what you are likely to be doing, and make an educated choice. Personally, I would choose a Clip point, because I do quite a lot of delicate work, but it is up to you.
If you are likely to be doing much skinning or gutting, then you might want to consider a serrated or wavy blade, which cuts through flesh like butter, but is harder to sharpen in the field.
Step 9: Blade hardness
The hardness of the blade is measured using the Rockwell Count scale (RC scale). It is determined by teh heat treating of the blade as it is made.
High hardness (~ RC 60-65):
This is more brittle, but holds an edge very well. Impacts may cause the blade to chip, so it is suited for small knives and general cutting.
Medium hardness (~ RC 58-60):
This is suitable for a wide range of tasks, and is what you would want for a general purpose survival knife. It holds an edge fairly well.
Low hardness (~ RC 52-58):
This is the least brittle, but does not hold an edge as well. It is used for impact blades, such as meat cleavers and axes.
Step 10: Handle
Handles are made from a wide range of materials, such as plastic, bone, horn, wood, leather and rubber. Rubber provides good grip, even when wet. Bone and horn are durable, and also provide an aesthetically pleasing finish. Wood and leather have a nice finish and a good grip, but will need some treatment to stop them deteriorating. Plastic is strong and not absorbent.
The handle should comfortably fit your hand, and not leave blisters with prolonged use. This is down to personal preference.
A guard between the blade and handle will help protect your hand. A single guard is generally better than a double, because it enables a range of different grips.
Step 11: Sheath
A knife should have a sheath, to protect both it and you. A sheath should be made from a strong material, such as leather or Kydex, and have a tunnel belt loop. Also, the handle should have a strap to stop it sliding out of the sheath. Some sheaths have a small pocket for a sharpening stone, which is extra weight but could be useful. It is up to you where you where your knife, on you belt or leg or wherever, but the police may not like the idea of a concealed blade! In public places, you should take it off and put it deep into a bag, or better stilll, not carry it unless absolutely necessary.
Step 12:
I think I have covered everything, if you think of anything else, then tell me. You may have noticed, but there is no perfect survival knife. Nobody can predict exactly what will happen to them, so a knife has to adapt. Finally, be safe when using a knife, I have seen many injuries due to carelessness, but enjoy the outdoors.
Step 13: Knife Steel Type
There are countless different types of steels, but for a survival knife they fall into two categories - stainless and carbon. Stainless is more rust resistant, and can be more brittle, but does not hold an edge so well and is harder to sharpen. Carbon steel is tougher, easier to sharpen and holds an edge well, but may rust if not cared for.
I have no experience personally, but i found a list here of some recommended survival knife steels.
Recommended Stainless Steels
S60V
BG-42
S90V
CPM S30V
CPM 154 (this is my favorite stainless steel)
Recommended Carbon Steels
D2
A2 (this is my favorite carbon steel)
O1
Carbon V
CPM 154
If you want to do more research, then this link is very good.
Step 14: Image Sources
http://applepublicrelations.com/images/gavel_xncx.jpg
http://asrafffariz.blogspot.com/2011/03/knives-chronicles-tarzan-rambo-macgyver.html
http://www.robscooking.com/?p=453
http://www.ocmulgeeblacksmiths.org/knifemaking101.shtml
http://mountainpreparedness.blogspot.com/2011/04/knives-as-tools-review-of-knife.html
http://shootingmessengers.blogspot.com/2010/08/knife-blading-101.html
http://chestofbooks.com/crafts/popular-mechanics/Things-To-Make-In-Home-Workshop/How-To-Keep-Your-Knife-Keen.html
http://airgun-academy.pyramydair.com/blog/tag/rockwell-scale/
http://www.aceros-de-hispania.com/herbertz-knives-penkives.htm
http://creationsbychris.us/leather_accessories
simondburt says: Mar 25, 2013. 6:31 AM
Loving the advice! I will be changing up the way I sharpen all my blades now!
I have been working in the USA for a number of years up in the white mountains, so I have accumulated a couple nice pocket knives, one of them being the same gerber as pictured above.
However, reading the law, as the bit you have posted in the article, I am not permitted to have this on my person anywhere in the UK...
Does this law prevent me from using this utility pocket knife, out on the trail? I am prepping for a late spring trek (c2c)
What about a leatherman? length wise its just within the 3" cutting edge limit, but they all lock open!
Sometimes these rules and regs of the UK can be such a pain in the butt!
anthonybarbuto says: Mar 11, 2013. 7:29 PM
Very well done and researched. I used to sell survival knives to the military. Let me tell you what the "pros" use. First, there is no one knife that does everything....thats why there are so many knife collectors who collect the many variations...then you have different makers...etc.
Pilots carried an assortment of knifes. The first is a pocket knife. The Mil-k-818 spec knife is a flat sided, stainless steel "campers type" knife. It has a 3 inch blade, a can opener, a bottle opener and an awl. It has a bail so you can attach a line on it so that you don't loose it. Several companies used to make these....Camillus ( now out of business)...I belive the Ontario knife company still makes it. It retails for about $40...sometimes you can buy them surplus for less. The next knife I sold was the pilots knife. There are several....One USAF knife has a Parkerized blade about 5"....it has a saw tooth blade on the top of the knife. IT has leather washer handle in a leather sheath. Most useful is a sharpening stone. Between the blade and the grip is a square hilt with two holes on it. These holes are to lash the knife to a pole or stick to use as a spear. There is a hammer type but cap to use as a ....what else...a hammer. Altho this styke has been around since WW2...it has a lot going for it....full hilt thru the grip.... the sharpening stone and lash able holes. The Kabar knife is excellent...but is a bit big. I don't think you should have s survival knife with a blade 7" or over. IF you want a machete...carry a machete....Stay away form the Movie knives as mentioned in this excellent article. I also believe you should stick with carbon steel as it is easier to sharpen. All u need do to protect the knife from rust is to oil the blade from time to time......Look at used bayonets, even from wW2. The steel and design is good....just get one with a reasonable blade length ...less than 7" and a grip that is comfortable for your hands, There are a lot of Russian bayonets coming into the country for about $20-30....with a sheath. IF the bayonet has any large fittings to attach to a rifle these can be removed or ground off...I know that custom knives cost hundreds of dollars...but if you have a good knife that meets many of the above criteria,....you should have a good tool...weapon..... be wary of a knife that is too cheap...the steel may be inferior ...or the handle may break...not what you want in a survival situation...again...the military knifes have passed a specification which calls out the quality of the materials and the testing criteria...they are pretty tuff...
8steve88 says: Jan 20, 2013. 6:40 PM
A very well thought out and written piece. Lots of good info on steel types, this often gets overlooked in favour of the image the knife portrays.
If I might suggest a good cheap starting point, a sort of easy way into the survival knife choice, the Hultafors heavy duty knife is a good all rounder while the blade is a bit on the short side it's an ideal camp knife. It is available for £6 at Jan 2013. Carbon steel, large plastic handle and a plastic sheath.
I found it to be an excellent "starter" knife to get you into caring for your blades and at the price it won't matter too much if you mess it up.
Schmidty16 says: Nov 10, 2012. 11:06 AM
like this its a gerber knife
abadfart says: Oct 26, 2012. 6:08 PM
most think this is overkill its a 8" blade with a compartment in the handle and a saw in the spine
xinistrom says: Aug 26, 2011. 8:41 AM
what about this one? its 9 inch with 4.5 inch blade and full tang
AntMan232 (author) in reply to xinistromDec 29, 2011. 4:48 AM
Unless you need to take down an enemy soldier, a double sided blade is unnecessary. It stops you using your thumb on the back of the blade, and means you can't baton so well.
black hole in reply to AntMan232Jan 26, 2012. 3:00 PM
True, but it also means that you have twice as many edges, which means you have a backup edge, as it were.
Also, what do you think of the Gerber LMF II ASEK as a survial knife?
A flyin muffin in reply to black holeJul 23, 2012. 11:29 PM
Twice as many edges isn't as important as a solid spine. In survival, you would be mostly doing chopping work. Chopping wood for fire and shelter are two major ones. Having the double edge makes it impossible to hit the spine of the blade so that it can be driven into wood. Think of an axe. It is heavy, so when you swing you have a lot of force to drive the blade into wood. With a smaller knife like this, it would be almost impossible to even cut up some fire wood. To make up for this, you could hit the spine of the knife with a rock or a piece of wood. If you have a double edge, you can't do that. The tip also becomes weaker. The finer work like whittling that requires a sharper knife is only used in long term survival situations. About the blade that you were asking about, that is completely tacti-cool. Both sections are too short to do any real work, and why would you even need the serrated edge? Stainless steel is a huge no no for knives. It cannot hold an edge well. I would stay away from that knife.
black hole in reply to A flyin muffinJul 26, 2012. 8:34 AM
I agree, but it still can't hurt to have a double edged blade as a secondary.
Brazilian Saber Tooth says: Mar 2, 2012. 2:23 PM
Very usefull information and I will probably use some of your tips in my tryings.
rusty0101 says: Feb 12, 2012. 9:15 AM
From the research I've seen, another place you see the convex grind is on true katana sword blades. A critical part of this however is that the entire convex surface is polished rather than simply sharpening the edge and polishing the rest of the blade as is often seen in the knock-off blades. That said, I do not know how useful this is on a 3-6" knife. There would be a significant amount of work to do every time you went to sharpen the blade. And as a utility or emergency knife, I'm not sure that it's a practical edge.
Isurvival says: Jul 24, 2011. 3:19 AM
I like the information you've given, but my ecperiments prove that the easiest blade to sharpen is a flat grind or saber grind as you called them-since you don't need to put as much effort on sharpening it, as if you lay the blade to the sharpener, it wil automatically give you a decent sharpness after a few strokes...in my opinion of course...
black hole in reply to IsurvivalJan 26, 2012. 3:05 PM
Nah, the chisel grind is easiest to sharpen. Only one side, not two. Look at the Emerson CQC-6.
AntMan232 (author) in reply to IsurvivalJul 24, 2011. 5:25 AM
I agree with you about the flat grind/saber grind being easiest to sharpen. I am fairly sure that if you examine some edges, people inadvertently make a double bevel, because the very end of a double bevel is effectively a saber grind. People, if they aren't paying special attention, tend to sharpen just the edge of the blade, to the angle changes, making a double bevel.
Isurvival in reply to AntMan232Jul 24, 2011. 12:54 PM
well-just as you said-it is pretty easy to make this mistake even with some skills-so this way, I can say you are right-and as I said earlyer, I really like that you collected all of this information and made it accesible to anyone-thanks again!
Tenebrioun says: Sep 9, 2011. 7:00 PM
I don't mean to lessen the value of this instructable. This instructable has a great deal of very useful information about knives that is rarely found in one place. Thank you for this reference Antman.
/genuine
Tenebrioun says: Jul 27, 2011. 12:47 PM
Rat tail tangs are spot welded onto the blade. They are also typically 1/4" or thinner thickness. These typically break through any sort of real use. As in break off of the blade. If the handle breaks, this will too.
mace242 in reply to TenebriounAug 7, 2011. 7:23 AM
Not so. Look at Sami knives. Stick tangs mostly but one bit of forged metal. Ive never seen a stick tang welded on. Got an example?
Tenebrioun in reply to mace242Aug 7, 2011. 11:27 AM
The Sami knife seems to have a push tang, not a rat tail tang. We may be mixing terminology but a rat tail tang in almost all examples is welded on. Can you show me some examples where the Sami clearly has a rat tail tang? In the few examples that it is not welded on it is still(like most tangs) made with a non-tempered(ie: soft) steel for flexibility. The problem is that compared to any other tang, this presents significant weakness from the distinct lack of material compared to other types of tang. Furthermore, They have a tendency in regards to keeping the handle on and straight as it's only kept on by a bolt or peened into place. While fine for many other uses, these two methods are incapable of holding up to the stresses a knife that is used often go under. Because of the dimensions of a square rat tail tang(it's a square) as well as the fact that it's a cylinder for the screw types, the blade has a bad habit of shifting a in a circular fashion causing the potential for serious injury as it will shift in the middle of using it. In the end, if there's a rat tail tang, the maker was likely going for cheap, not good. Think of how much effort it would take to put in a half push tang or full push tang as opposed to a rat tail. While I stand by what I said about the durability of rat tails, I want to reiterate, nothing is holding a rat tail straight, when you are cutting you are putting a great deal of force on the blade of the knife. Does this make you feel safe?
As far as examples, any sword under $70) and most fixed blade knives under $30. There are exceptions, not all makers price the same(of course in that price range I wouldn't buy from a maker). Few people advertise a rat tail tang as it's considered undesirable for the reasons mentioned above. This means only honest or the unknowing tell you it's rat tail and that means most people won't tell you if they can help it.
Last word: Rat tail tangs are cheap and can be dangerous in an often used knife. Most people who have a fixed blade have bought a cheap rat tail and they either found out the hard way or don't use it very often at all. Below are some informational links on rat tails.
http://en.wikipedia.org/wiki/Tang_%28weaponry%29#Hidden_tang
http://netsword.com/ubb/Forum1/HTML/001780.html
http://www.swordforum.com/forums/showthread.php?45577-rat-tail-tang&highlight=rat+tail+tang
myfacelackseyes in reply to TenebriounSep 9, 2011. 4:11 PM
I often hear this rhetoric about rat-tails and while it may be an issue with a sword which experiences much greater forces at the pommel, I have never seen a knife blade rotate or slip- with any fixing. If you are using your knife in a controlled and safe manner there should be very little shear force on the joint between the tang and the blade. A person is capable of exerting at most 400N (roughly 40 kilos of force) with a knife blade, if you look at the shear strength of mild steel you will see how little is required for withstanding that. A short knife should be battoned through wood for chopping which exerts almost no force on the pommel (you'll notice the hand holding the handle of your knife does not tire or ache during batoning).
As a final note, one of the most popular and highly recommended beginner bushcraft knives (which if you are talking survival is the way to go; if you want a fighting knife you are looking at something completely different) is the 'Frost Mora' constructed with a half tang and a very thin blade, look through the reviews on amazon or on any bushcraft/survival forum and see if anyone has managed to break on of those.
Tenebrioun in reply to myfacelackseyesSep 9, 2011. 6:50 PM
I don't disagree with you on half tangs in even a small way. I only disagree with utilizing rat tail tangs in any situation. But as we know, these are two different tangs.
I have seen slipping and rotating on a rat tail knife. I spose that's one that does and one that does not.
With regard to the information on shear force, I'm not referring to a solid piece. I'm referring to when the tang is welded on. I believe you can weld a rat tail(or any tang type) on very well, but if you're putting the effort into welding it on well, you're not using a rat tail. This isn't a "it cannot be done" it's a "if [this] than [that]".
Thinking on it again, I still don't understand where the comment about a half tang knife came into this, genuinely.. The Frost Mora has a 2.5 mm thick blade and tang. Also, the tang is half tang, it doesn't seem to apply to this conversation.
nakigara says: Aug 16, 2011. 10:45 PM
An important part of the blade (especially for tasks like skinning) is the belly - the curve of the blade towards the tip. One of the reason clip points are favored is because they have both the sharp point and a sufficient belly.
Personally, I'm fond of drop-points (pretty much the opposite of the sheepsfoot - the spine is straight to the point, and the edge curves towards the spine (like a rounded tanto)) - it makes for a really strong tip, yet possesses a belly for skinning/whittling/whatever (very difficult to do with a tanto point)
I'd also strongly recommend against a serrated blade for a survival knife (especially if you are planning on using it for skinning or gutting). While serrations can be really helpful for fibrous materials like cloth and rope, and give the knife a sawing/tearing ability even when dull, they also make it extremely difficult to sharpen, and make tasks like skinning and whittling nearly impossible (both would be quite useful to make tools/prep food).
Anyways, not to get too detailed, but yeah, a clip point is generally all around-good, and frequently favored by a lot of people, and can do most tasks well.
nakigara says: Aug 16, 2011. 10:28 PM
I'd say the one exception to the hollow-handle knives would be the chris reeve one-piece, although anyone familiar with them (or willing to drop that much on a blade) probably knows what to look for and what they want...
I've also seen a few handmades where they have a full tang, but hollowed out and removable handle scales for stashing a couple tiny things like fish hooks or a flint or something.
spylock says: Jul 29, 2011. 1:58 AM
what a drag that the laws are so strict you cant even carry a blade of your choosing,they were trying to ban the assisted open blades here in the States,but we raised a stink and they left it be,at least here in Virginia.I have arthritis in my hands and they make it alot easier on people like myself.I dont understand the banning of weapons,if a person is dead set on harming someone,he or she could use just about anything as a tool of harm.
GhostSnake says: Jul 28, 2011. 11:30 AM
Nice guide! Nevertheless you forgot to mention important stuff like the tanto point and americanized tanto point (those two are good for heavy work, prying and stabbing because they have the strongest tip).
It is also worth mentioning blade thickness (I personally prefer 0.25in thickness as I favor durability over anything else). Also that extra thickness allows you to strike harder and use for prying or hammering.
A paracord handle might be a good idea since it can be replaced at any time or used for other purposes such as making as spear. Full tang always (rat tail may still break).
For steel I like S30V because it is very durable and stainless. Also INFI steel (from Busse) is incredibly strong although not very stainless. A good but cheap one is 440C. One must remember that knife makers may give different treatments to those metals.
Finally it depends on what do yo want your knife for. I like my knives for survival AND collecting, so I favor extremely durable, although expensive knives but if you only care for the survival more than the knife itself you can get almost the same results with far cheaper knives. Top notch brands would be "Strider knives", "MercWorx knives" and "Busse knives". For the inexpensive yet incredibly useful I recommend "Muela knives".
I also particularly recommend a small uitility knife that still covers all my points mentioned above: the Strider WP-T (or Strider WP Tanto). You can get it with almost any kind of tip you want if you don't like tanto points. Google it.
Nice guide again! Very in-depth and well thought out.
Srider WP-T (Black) 1.bmpStrider BN vs branch.jpgMERCWORX_SNIPER_CHILI_knife.jpgBusse HellRazor 1.jpgBusse HellRazor Bowie.jpg
schkip1973 says: Jul 26, 2011. 6:29 AM
i'm not into knives above any other tool. for instance a chisel can be as sharp as a knife and do as an effective job, as will a fist, credit card, language or a smile.
for mine a leatherman style product has been the most effective, and any other options have been covered as part of the every-day carry philosophy.
Good luck!
kingsqueak says: Jul 23, 2011. 10:47 AM
Covered a lot of ground, nice.
For cutting tasks, don't buy too heavy, thick, or long of a blade. The knife with the polished blade and wood handle has a blade profile similar to a Buck Nighthawk that I own. It is a good bush knife for heavy use, but is not the ideal for things like food prep or skinning. This type is good for bushcraft and other heavy tasks though.
For actual standard cutting, you can get really excellent deals on Opinel or Mora. They easily keep a razor sharp edge (particularly the carbon steel versions) and for food prep or fine cutting they will last a long time.
Once you learn about basic steel types, you can save a ton of money if you are buying for basic utility. For actual use, beware spending on the design, appearance and exotic engineering of a basic blade...unless you are buying for collecting purposes. Spend your money on the steel for the purpose intended.
AntMan232 (author) in reply to kingsqueakJul 24, 2011. 11:24 PM
I agree, ideally you would want at least two knives in a survival situation. I really like the Mora knives, I have a spoon knife made by them. I have also added a brief page on steel types. Thank you for the feedback.
Ranie-K says: Jul 24, 2011. 2:18 AM
Writing "Google images" is NOT enough!
Like this picture: http://en.wikipedia.org/wiki/File:Ground_blade_shapes.png
You need to write "Waerloeg" under it -she/he made the picture -not Google!
Attributing pictures using "Google images" is like saying a street sign pointing to Paris made the Mona Lisa!
Also, you have licensed this article as "Public Domain". Since these pictures are NOT all licensed public domain, you are not within your rights to re-license these pictures as "Public Domain".
AntMan232 (author) in reply to Ranie-KJul 24, 2011. 2:09 PM
Thank you very much for your so very helpful comment, I have since added a sources page. I realise that I incorrectly cited the images, and I am very sorry if that has offended you. Could I also recommend that it might be nicer for authors if instead of criticising people for their image sources, as you have on a few peoples instructables, you offer some encouragement or praise. Your point might be taken in better if people have a reason to like or respect you, rather than just pointing out mistakes.
richardsalt says: Jul 24, 2011. 1:16 AM
Many thanks. Excellent summary and very well illustrated. Came at a particularly opportune time - have been considering a purchase for some time and needed guidance.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
