How to Chunk a Pineapple Like a South Seas Island Boy
Introduction: How to Chunk a Pineapple Like a South Seas Island Boy
I could not find very much on the web about the best way to cut a pineapple into chunks so I decided to use this forum in order to pass on the secrets of the island boys who do this for a living. This skill has been passed from father to son for generations but is in danger of being lost in our modern mechanized world.
Island Boy Tip: Please be careful when using a knife for any purpose. You must respect the blade. It can cut you.
Step 1: Be Sure to Choose a Ripe Pineapple
Island Boy Tip: You can tell a ripe pineapple by the smell. Just sniff the bottom (stem) end and if it smells like fresh sweet pineapple, it's ripe. If not don't buy it. Pineapples ripen on the plant before they are picked and will not ripen further. Make sure the flesh is firm, not soft. Don't worry about the brown leaf tips.
Step 2: You'll Need Two Tools
1. A large knife to cut the pineapple into sections.
Island Boy Tip: Use a serrated bread knife unless you have a razor-sharp machete or chef's knife.
2. A small knife to cut the sections into chunks.
Island Boy Tip: Use a fillet knife or thin boning knife.
Step 3: Lop Off the Leaves
Island Boy Tip: Leave a small section of leaf stem on the end. This will hold things together.
Step 4: Cut the Pineapple in Half
Step 5: Cut the Halves in Half
Step 6: Cut the Quarters in Half
So now you have eight sections.
Step 7: Insert the Filet Knife Into the Leaf Stem End of One Section
Island Boy Tip: Insert the knife below the central core and above the outer skin. This is the secret to keeping everything together at this point. This makes the following steps much easier. You won't find this tip anywhere else.
Step 8: Cut Forward Away From You
Island Boy Tip: Go close enough to the skin to keep most of the flesh but don't go too close or you'll get undesireable eyes in your chunks.
Step 9: Cut to the Other End of the Core
Island Boy Tip: Continue cutting away from you, then go up toward the core but don't cut through it.
Step 10: Cut Back Toward You Below the Core
Slowly! Be careful not to cut yourself! When you get half way through, grasp the section at the other end and continue cutting toward you.
Step 11: Cut All the Way Back and Cut Through the Leaf Stem
Hold the section in the middle while doing this.
Step 12: Cut Through the Core at the Other End
Step 13: Remove the Core Piece
Step 14: Cut the Flesh Into Chunks
Island Boy Tip: Cut down and pull the knife toward you slightly. Cut just above the skin but not all the way through it and chunks will stay put.
Step 15: Grab the Whole Section and Dump the Chunks Into a Bowl
Step 16: Do the Same With the Other Seven Sections
Step 17: You Now Have a Bowl Full of Nice Clean Pineapple Chunks Cut the Island Way! Enjoy!
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Epilog Challenge 9
      Epilog Challenge 9
    As a born-and-raised Hawaii resident, I can suggest the normal method of cutting into eighths by circumference, but 16ths are not unheard-of for things like salad and toppings. Top and core it first though, and do not use the bottom 1/4" of the pineapple for the noob.....It is an "apple" structure, but the bottom is not as sweet as the rest. Use a very sharp knife to carve a pineapple as the skin is tough and armored like an armadillo. Do not bake pineapple slices over 300ºF. If making a pizza, top with cold pineapple in the last 10 minutes of baking for best results. Canadian bacon, canadian ham, and pineapple make the typical "hawaiian pizza" by american-continental standards. The top and the bottom are the toughest part, so either eat them to clean your teeth, or pulverize them skinless in a blender for a "pulpy" Hawaiian cocktail drink. The flavor is just as sweet, it's just tougher to bite through. Dole Canneries does the best job in canned pineapple from Hawaii-grown farms last I checked. California-grown simply does not make it as sweet as it can be from Hawaii, and that's not a hometown bias.
    Might I add, if you bought pineapple imported, remove it from the metal can right away, as the citric acid reacts with the tin, producing a metallic taste. Import as fresh as possible and remove from metal cans ASAP. I am born and raised....I know canned from fresh, where whole pineapples were 59¢ each, even if they weighed 2 lbs. Pineapple reacts with galvanized tin....remove it and store in HDPE right away to retain flavor and freshness. Consume within 18 days of picking or 12 days of delivery on the west-coast (california) for best quality. Do not buy "fresh" pineapple on the east coast, as it cannot possibly exist. The real thing comes from Hawaii, a subsitute comes from California, never accept anything otherwise or you'll never enjoy it for all it really is. The East Coast suffers for that, as well as they suffer from the lack of general culture......sad that.......
    Lack of general culture? Wow, really? I live in east Tennessee and we are full of culture here.Sure, we don't have native pineapples here, but we have so much more! You sound ignorant.
    I know there is a tool that can cut all the pinapples for you. It saved lots of my time. Find more info of the tool by searching google "pineapple easy slicer art creativelife "
    Yeah, I considered that when I decided on this method. It got lots of bad reviews. The plastic blade was not sharp enough and it broke easily. There is a metal version which looks better but is very expensive.
    Excellent! I like to buy fresh pineapple at least a couple times a month, but my "chunking" method has always been a little suspect (and messy). This looks like it'd give me much better results. Can't wait to try it out!
    so, is it true that pineapple workers don't have fingerprints because the stuff in pineapple eats them away?
    The enzyme is called bromelain - a proteolytic enzyme. (It cuts proteins and is often used as a meat tenderizer.
    wow. I've never heard that, but it would be interesting to find that out.
    well... it was a plot line in hawaii 5-0.... but wikipedia seems to say it is true...
