3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Clean A Bolt Action Rifle
In this, my first, instructable you will learn how to clean a basic military (or civilian for that matter) bolt action rifle.
Cleaning is one of the most important parts of gun care and respect. The more you respect them, the better. I'm not going to give you a speech :).
Also, especially with a military relic like this, taking care of the rifle keeps its value high and makes it perform a heck of a lot better.
Major Materials:
-Cleaning Rod, at least as long as the barrel of the rifle you are cleaning. Check Wal-Mart.
-Cleaning Patches, for the caliber rifle you are using. Can be found at most sporting goods/ gun s tores, even Wal-Mart
-Solvent, whether it's Hoppes 9 or Gun Scrubber it doesn't matter. This can be found once again at sporting/gun stores and most of the time Wal-Mart.
-Rust Protector, like Barricade in the photo or others.
-Some way to hold the rifle in place, I used sandbags made for shooting and a regular vise with a towel draped over it keep it from marring the wooden stock. They do make gun vises just for this purpose and if you are doing a lot of cleaning, you should consider getting one. Last I checked they ran from about $50-$200.
-Disassembly Tools, you need the tools that are required to disassemble your rifle. Often this is none at all or just screwdrivers. Some rifles have special tools (ie. M1 Garand, Mosin Nagant, SKS/AK sights) that are made just for them. Most of the time they are not necessary and can be replaced by normal consumer tools, but help a lot.
-Disassembly Guide, how are you going to clean it if you cannot take it apart? Some rifles come with a manual from the company that imports them (mine was from Century Arms) and you can buy take-down guides at most gun stores. Also, you can find instructions on how to take-down military rifles at SurplusRifle.com.
-Place to store small parts, not really required but helps a lot. I found a small organizer in the sewing (I think?) department of Wal-Mart. I can't tell you how many times I have dropped a screw or something of the like and spent hours searching for it on my garage floor. It's nice to have them all in one place.
-Last but not least, a spacious place to work, I use the workbench in my garage, but most places will do. You need at least enough room to fit the cleaning rod down the barrel. Remember that most of the solvents and chemicals need to be used in a well ventilated area, so do so. Personally, my garage workbench is a little too small, but it will do.
WARNING: Guns by nature are dangerous, and I hope you would know that. Always make sure the gun is not loaded in any way. In addition, some of the chemicals or solvents used when cleaning are toxic to breath or touch. Where the proper safety equipment (gloves, respirator, etc.) And for God's sake don't get the stuff in your eyes, or you will be sorry (I know from experience!) Therefore, while cleaning a gun shouldn't be dangerous if you do it right, I am not liable for any injury or death sustained while doing this. Don't be stupid or careless, always use proper gun safety even when its not loaded, and while cleaning. PLEASE BE CAREFUL.
Step 1Make sure the rifle is UNLOADED!
This is probably the most important step. Open the action of the rifle and visually check and make sure that there are no rounds loaded or in the magazine (if the rifle has one).
You wouldn't want to be killed (or kill someone else) by the unloaded gun would you? This takes all of 20 seconds but is a crucial safety step.
Well, you get the point, don't be stupid and careless!
74 comments
1-40 of 74next »
May 17, 2008. 11:55 AMLockervomHocker says:
Its a important question, how often i have to clean my gun.? Its like with a good shave, how often you think you need a shave? If you like yourself you will say "often" and you see if you like your rifle or your gun. You will say the same, when we talk about the cleaning of rifles or guns. But to make it easy, transform the question "how often i have to clean my gun" to "how safe is my gun without cleaning" Thanks to the Author, fine work.
Mar 5, 2012. 11:15 PMsilverlupe4 says:
you should clean your firearm after each use!!!!
Dec 14, 2011. 8:03 PMTux0r says:
It depends on your firearm, I just clean it after i'm done shooting and back home, short-term storage : light oiling after cleaning, long-term storage : heavy oiling after cleaning and a once-over with a silicone impregnated gun rag to get the acidic/corrosive finger prints. Though you should clean them of finger prints anyway before you put them into the gun case.
Jun 26, 2008. 1:35 PMbackyardpyro217 says:
clean it after every 20-25 rounds and lube and rust proof constantly, it's impossiible to overdo it but make sure you get excess as it will effect performance over time
Apr 12, 2012. 6:44 PMJacob Veta says:
thats a bit much. bear in mind that the rifle he is demonstrating was used for 16+ hours between cleaning by the soviets in WWII.
Jun 23, 2009. 10:36 PMCoffee bean says:
20-25 really i clean after every use about 200 rounds but it's just a .22
Oct 10, 2011. 9:20 AMjerry303 says:
y is my bolt for my 303 so hard to get in i took it out to clean the gun now i cant get my bolt back in
Oct 27, 2010. 3:15 PMjellybean10122 says:
Where it says the cleaning patch is almost the same size, (7.62)
Isn't the mosin 7.62x54 anyway?
Oct 7, 2010. 5:21 PMpsyoper22 says:
beautiful rifle. i'm quite envious.
great cleaning instructions, except you really shouldn't use hardened steel tools for cleaning any firearms. you should use tools made of brass; ones intended for use on firearms. i gave you 4.5 stars, but it would've been lower if you were handling something rarer, like a 1887 winchester lever action.... =)
Nov 15, 2008. 4:57 PMthoraxe says:
damn man, that is one sexy rifle. did you buy it or was it a handed down?
Feb 6, 2009. 11:53 AMKarikaru says:
They have specials on these at Big 5 for $99. I paid $139 for mine, but it was a "hand picked" one from the warehouse (means a little bit better condition), and it has matching serial numbers. These aren't exactly priceless antiques with something like 20 million of 'em floating around the globe, but there are circles that collect them for their historic value. I imagine if you collected them now and took care of them, you could start a tradition passing them down to your kids and by the time your grandkids are your age these rifles might be worth something.
Sep 30, 2010. 4:17 PMFreedster says:
Closer to 40 million. :)
http://en.wikipedia.org/wiki/Mosin–Nagant
I own one myself, got it at Cabela's for $99.
Aug 10, 2010. 4:43 PMsarge69 says:
7.62 and 30 caliber are exactly the same
Aug 23, 2010. 7:09 PMtheburn7 says:
Only in bore diameter, but a 7.62x54r is much different than a 30-30 or 30-06 .308 too. Next time, get your facts straight and never shoot the wrong ammunition
May 10, 2009. 11:48 PMDrWeird117 says:
Damn it, I can't find a Mosin. Where'd you get one?
Jun 23, 2009. 8:09 PMCoffee bean says:
aim surplus had them for a while
Jun 23, 2009. 9:06 PMDrWeird117 says:
Huh...
Jun 23, 2009. 10:21 PMCoffee bean says:
Aimsurplus had them but not any more(check them out anyways.)
ImpactGuns now has them
May 15, 2010. 5:57 PMtyeo098 says:
Or any pawn shop that sells guns.
One guy had a *ugh* laminated Nagant, labeled as an SKS, for 467$.
Really? He couldn't tell the difference between a bolt action rifle, and something resembling an AK? REALLY?!
May 15, 2010. 6:11 PMCoffee bean says:
 Thanks sad, correct my if I'm wrong but I think that high for an SKS?
May 15, 2010. 7:25 PMtyeo098 says:
Depends on make/model etc but its in the higher range.
But it doesnt matter because it was a regular ol laminated nagant.
Jan 11, 2010. 1:24 PMPbyrd says:
Nice Instructable. I also have a Mosin-Nagant, but mine came with all of the tools for the gun. When I clean it, I use the original tools and cleaning rod to disassemble and clean it. What year was your's made in? Mine was made in 1939, btw.
Jan 3, 2009. 3:18 PMgun487 says:
Very nice rifle look very new is it a ww2 production? or later years im buying a mosin nagant im trying to get a early production but your looks very sexy =P
Oct 11, 2009. 12:48 AMdla888 says:
I kinda think a Mauser Model 98K looks very nice, but that's probably the German in me.
Feb 6, 2009. 11:47 AMKarikaru says:
Judging by the sites and the receiver, I'd say it is a later production 91/30. If those holes are original on the receiver, it's an ex-sniper probably from Izhevsk arsenal (Soviet Russia). I'm somewhat of a newb mosin collector. I just got my 1943 Izhevsk m91/30 this week. It's been fun going to 7.62x54r.net and identifying it. Just a note on mosins: they require a lot more attention when firing the old surplus ammo. it is corrosive and will eat up your barrel if it is not cleaned after shooting. I've heard a mix of ammonia and water helps to neutralize the corrosive stuff. Those interested in this rifle should definitely check em out! They're some of the cheapest rifles you can buy, but very reliable and accurate - plus they're historical.
Jan 11, 2010. 1:30 PMPbyrd says:
Yeah on the topic of surplus ammo, I wouldn't even buy it. You can get new made Russian ammo for a pretty cheap price and it isn't corrosive. Most surplus ammo says it isn't but most of the time it is.
Feb 15, 2009. 8:51 PMgun487 says:
Sweet lol the other day i found a fairly sweet deal at dunhams a mosin nagant 91-59 for $120 might be a soviet sattelite country production but is the same rifle and for a cheap price ive read up about it and all the numbers match up on most of them and there fairly accurate so im looking into it =}
Feb 16, 2009. 11:48 AMKarikaru says:
Sounds like a good deal. I also saw that Big 5 in my town has the 91/30's for $90 this week, so that might be an option for you too if you have one around. A big thing that will determine accuracy is the bore of the rifle. You can remove the bolt pretty easily by just uncocking it and pulling it back and then pulling the trigger and sliding it the rest of the way out, and then holding the barrel up to a light and looking down the bore. The lines of the rifling should be pretty crisp and look for signs of pitting and rust and overall cleanliness. I recommend going for one of these as opposed to a fancy new rifle, because you'll save yourself a lot of money and the value on these will go up, because they're collectors while the value of a new rifle will go down as newer models come out.
Jul 23, 2009. 2:37 AMtheburn7 says:
heh, i have a mosin nagant too, its m44 model Izevsk factory post war stock, and it is nice
Apr 7, 2009. 6:46 AMrasta74 says:
Thx a lot for the step by step instructions on how to clean a bolt action rifle. It was very helpful to me and anyone thats not familiar with a bolt action rifle, this would be the page to look at. Very detailed and simple. Q-tip is the correct spelling. Thx again. Rasta
Feb 18, 2009. 5:33 PMhappybirthday says:
Very nice Mosin Nagant. My uncle owns one
Jun 28, 2008. 7:15 AMaleigh45 says:
what type of bolt action rifle is that
Nov 15, 2008. 4:54 PMthoraxe says:
a mosin-nagant 91/30.. he said that....
Jun 28, 2008. 7:17 AMaleigh45 says:
nevermind
Jun 26, 2008. 1:47 PMbackyardpyro217 says:
i have the same brand cleaning kit except its for .177 and .22 caliber ( the handle for the rod is very distinctive )
Jun 26, 2008. 1:42 PMbackyardpyro217 says:
heres a very important tip, when you get a new rifle before you even think about sighting in fire 1 round clean the barrel and only lube everything the first time and then repeat for 20 rounds cleaning the barrel after every shot. What this does is it works grooves into the rifling which gives the rifling better grip on the bullet and cleaning it kepps bebris out of those groves because if it does it drasticly effects muzzle velocity acuraccy and speeds up barrel wear.
Jun 26, 2008. 1:27 PMbackyardpyro217 says:
Thats a cheaper remake of the .303 Brit I've seen them before, It's lighter than the .303 whose stock tapers evenly down to the end of the barrel, It's a good rifle but you can't beat the original
Jun 10, 2008. 12:56 AMgolfer12345 says:
me to althoe i like ww1 ww2 guns
May 31, 2008. 10:21 AMA_squared says:
Once agian, Love the gun.
Jul 29, 2007. 5:15 PMandy60 says:
i have a crosman 2250b, but i never clean it, how often do you think i need to clean my rifle(i only got it in august of last year)
1-40 of 74next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:tyleestuff
