How to Clean White Shoes- by Carter Byrd
1,934
13
Published
Introduction: How to Clean White Shoes- by Carter Byrd
Supplies:
Dirty pair of white shoes
small towel to wipe shoes
soap
sink
small bowl
all white shoe cleaner
Step 1: Use Towel to Wipe Obvious Dirt
You should see some immidiate improvement to the shoes with the less difficult dirt
Step 2: Remove Laces
Wash laces or replace if they are dirty
Step 3: Run Sink of Water and Put the Shoe Inside the Sink
make sure the water is warm. this will naturally help remove dirt from the shoe
Step 4: Put Water in a Bowl and Add Soap
this will help create a solution to clean the shoes
Step 5: Clean Shoes in the Water W/ the Soap
you should start seeing the shoe turn back to its original white
Step 6: Put Towels in Shoes
after soaking the shoes the inside may be wet so it is important to put plenty of towels in
Step 7: Let Shoes Dry for About 30 Minutes
It is important to make sure shoes are dry so the leather or material of the shoe is not damaged
Step 8: Apply All White Dirt Remover Spray
This will help polish the shoe and keep it from getting dirty in the future.
Step 9: Let the Spray Foam Up
this will allow for the foam to thoroughly remove dirt
Step 10: Wipe the Foam Off and Re-lace Shoes
At this point the shoes should be back to their original white form.
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    They look good :) I've heard that magic erasers also work well.
