loading
Picture of How to Clean and Polish Dirty Pennies (The Chemical Free Way)
Here's an Instructable on how to clean and polish your pennies and smashed pennies if they're dirty.
For all of you coin enthusiasts out there and elongated penny collectors, you will probably find this Instructable very helpful. I collect elongated pennies (you know, those penny smashing machines you see in museums and whatnot) however, after a while the pennies would start to lost their shine because of oxidation (in layman's terms: when the pennies are exposed to air, they lose their shine gradually)
I found out that you can restore the shine by rubbing a pencil eraser on the coin and therefore polishing it, however the process is long, hard, boring, and it kills your wrist.
The way I polish pennies uses the same concept, but is much more faster.
The pros and cons of this method are:
Pros:
-Cheap
-Decent shine
-No volatile chemicals/ fumes
Cons:
-Messy
-You could get a better shine with chemicals
-It would be faster with chemicals
(((Important Note)))
When I write Instructables I put multiple pictures showing multiple steps on only one step, so be sure to look at all of the pictures.
Step 1: The tools
Picture of The tools
 Here is what you need to do this:
-A small vice
-Power drill
-A  bunch of those cheap pencils you can get at the dollar store
-A small saw (like one you'd get on a multitool)
-Dirty, oxidized pennies just waiting to be polished
SirNoodlehe3 years ago
Great method, I prefer it over the chemical options because you don't lose any detail, 5 stars
Cherylb10033 years ago
All you need to clean copper is a salty acidic solution. Salt and vinegar work well, as does ketchup and as pointed out above, many many other solutions....almost all guaranteed to devalue a valuable coin.
As a coppersmith, I find the solutions are fast, easy, and get into nooks and crannies beautifully. While bright and clean, it may not be as shiny as you like and left long enough, detail may be lost (ie the Coke example above).
On my shiniest pieces, I use silver polish (not copper polish, it is abrasive and will cause scratches). Voila! a piece that looks like rose gold .... until a few days later when the normal copper patina begins to form.
A note to add, rose gold (the real stuff) does tarnish (albeit slowly) and does so more quickly that most other gold types (remember - 24K is too soft to be particularly useful, so other metals are generally added to make gold sturdy - that "other" usually tarnishes somewhat). Why? Because the copper to achieve the rose color tarnishes somewhat faster than other metals added during manufacture.
ripit3 years ago
that dark color is called patina and is best left on the coin but cleaning it with just soap and water will not hurt it just don't use abrasive cleaners and such if you value said coin and if ya use em for makin thing like jewelry, for polishing it brite you could add a dab of toothpaste!
bazalaz4 years ago
try using A-1 steak sauce and a tooth brush to clean pennies. not my idea, i got it online; but it works REALLY good... try it!!!! now!!!! then cook me dinner!!!
redwineau5 years ago
the absolute easiest way to clean dirty pennies is to submerge them in white wine. red wine works too. the acid from the wine strips away the grime, leaving behind beautiful coins. And the bonus is that the wine usually tastes better. This is a winemaker's trick--they use copper additions to balance wine before it goes to bottle, but many wines don't receive it, so the quick fix is to drop a penny into your wine glass.
However this will not work with pennies made after the mid 60's as they are not made of copper but other alloy's and as such will not work the same way in balancing the wine. Furthermore it would not be a good idea to drink any wine that has had a previously uncleaned coin(s) placed in it due to the fact that money is actually dirty as it has passed through many hands over its life and carries any number of germs / bacteria.
nice instructable very ingenuitive
Hi all!! If you follow these instructions and happen to use them on a coin that has some value.....financial, historical, rareity or sentimentality then all that "GOOD STUFF" ie: the value....... is all rubbed away!!! In other words if you clean a coin that has a value you will more than likely ruin it's value...... Professional coin collectors "NUMISMATISTS" will all say the same thing........... clean it .....KILL IT!! So be sure before you set about cleaning any coin that comes into your possesion be very sure it is not valuable........ here endeth the ....... WArning!!
920335 years ago
Drop a penny into a glass of 'coke'. Leave it there undisturbed. If you check back later and find it gone...not 'magic'...just 'disolved' completely by the acid in the cola. Now...imagine what cola does to the lining of your stomache over a period of years of drinking it regularly. Good for cleaning rust off chrome auto bumpers too. Just FYI stuff here.
Vertigo6665 years ago
 Dunking in cola also helps, as sort of a primer.  You'd have to wash it, of course, but as a "primer" of sorts it works quite well.  Also, if you are lazy (like me), you can just leave it to sit overnight.  It won't be shiny, but you'll be able to see it slightly clearer.
