How to Coleman slide longboards! by vanpaun
Step 3: What to do:
Set aside a good hour or so to learn. Put your helmet and gloves on, grab your board, and set out.
Get into the box position, and put your hand facing downhill behind you on the ground, and do a large, sharp, and fast heelside carve.
Lean in to your hand, and if you need to do it steez *. Steez is when you grab the board behind your back foot.
  • Steez isn't widely recomended, but I can't initiate a slide without it.
DO NOT do it stink-bug, or with you hand grabbing between your feet.
Really, what will help your success the most is to get out there and experiment with turns. It is hard to explain in words, so your practice and experimenting will be the most helpful.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
