How to Connect HC-05 With Arduino | Arduino Home Automation With HC-05 | Voice and Manual On/Off Control | Dual Mode
Published
Introduction: How to Connect HC-05 With Arduino | Arduino Home Automation With HC-05 | Voice and Manual On/Off Control | Dual Mode
About: Advanced and latest technology tutorials on my youtube channel and now i started instructable so i will post one by one latest tutorial.
Click Here for more Special Informations
Arduino Home Automation Demo with Android Control, Voice and Manual On/Off Control (Dual control Mode),
Requirement:
  1. Arduino Uno
  2. HC-05 Bluetooth module
  3. Breadboard (multi-functional board)
  4. jumper wires
  5. Android Device
Application use:
  1. Blueuino
Note: Before make this project, please watch this video for your overview and if you like this video so please subscribe my youtube channel.
Step 1: Step 1: Connection
Connect you Arduino with HC-05 as shown in pic and try to check ATmode with Arduino IDE terminal.
Note: Check it both side baudrate should be same.
Step 2: Step 2: Connect Your HC-05 With Android Device
You can download this app from play store,
https://play.google.com/store/apps/details?id=g.pa...
Step 3: Step 3: Now Check It, Your Led Will Blink on Android App Switching Mode
Note: when you android device is established connection with your HC-05 then HC-05 led will blink slowly. if its not connect with your android app then it will blink fast as normal mode.
Step 4: Step 4: Try to Use Voice Command
Note: you have to configure voice command in android app.
Step 5: Step 5: Arduino Code
char data = 0; //Variable for storing received data
void setup() {
Serial.begin(9600); //Sets the baud for serial data transmission
pinMode(13, OUTPUT); //Sets digital pin 13 as output pin
} void loop() {
if(Serial.available() > 0) // Send data only when you receive data:
{ data = Serial.read(); //Read the incoming data & store into data
Serial.print(data); //Print Value inside data in Serial monitor
Serial.print("\n");
if(data == '1') // Checks whether value of data is equal to 1
digitalWrite(13, HIGH); //If value is 1 then LED turns ON
else if(data == '0') // Checks whether value of data is equal to 0
digitalWrite(13, LOW); //If value is 0 then LED turns OFF } }
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
