There are already several way to use push buttons in your projects (e.g. hacking mouse and keyboard, or Arduino, gainer, MCK). This probides alternative way to use faders with audio input and output. With a tiny circuit (which you will make), you can get sensor data with audio!
As side effects, it provides you with precious sampling resolution and frequency than the previous ways (i.e. 16bit to 8-10bit, 44.1KHz to 1KHz).
You can see examples of this with CDS photocell, and distance sensor (SHARP GP2D12).
We also present a sharker percussion with accelerometer and an application of this instructable from a sound performance project AEO.
All you need is just a sensor, some soldering, and some software.
Note: This is for analog voltage produce type sensors only. This will not work on digital type.
Note2: This is a series of "How to coonect with Audio". Please see others: Button, and Fader.
Note3: Allison and Place developed the SensorBox. The device accepted six sensor inputs and two audio inputs. The data from each sensor was carried as the amplitude of a sine wave, and mixed back on the two audio inputs. They did not provide its technical detail well, however their approach was quite same as this instructable.
Remove these ads by
Signing UpStep 1The Parts
1 Circuit board
2 Transformer / ST-75
The transformer adjusts the voltage. In this time, we use 'ST-75' from Hashimoto-Sansui. However other transformer could be used if its satisfy the specification (e.g. TRIADSP-29). Currently we try to figure out they could be used or not.
4 Germanium Diode / 1K60 (1N60)
The diode allows an electric current to pass in one direction.
3 2-point Power terminal
For audio input, output, and power.
1 3-point Power terminal
For sensor.
2 RCA AudioPlug
One for audio input and another for audio output.
1 Quad Cable
For circuit and connectors. The length depends on how long you want.
1 USB cable
For power.
1 Pair of DC connector
For power.
comments
Add Comment
Add Comment
