3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Connect a Sensor with Audio Input and Output
Step 3Preparation: Power from USB
To obtain power for sensor (the circuit does not need power), you can use 5v (most sensor work with this voltage) from USB. Cut a standard USB cable and solder DC connector to voltage and ground sides (usually red is for voltage, and black is for ground, but you should check the correct line with multimeter).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:jojporg
