How to Control a Servo With Arduino
356
9
Posted
Introduction: How to Control a Servo With Arduino
Lets control a Servo Motor with Arduino! All the parts you will need i got in a handy little kit from GearBest, if you want you can check it out here!
The parts you will need are:
1) Arduino Board
2) Servo
3) Potentiometer
4) Wires
Let's Get Started!
Step 1: Piece Everything Togeather
I created the schematic in the picture, to make it easier to put together, then connected all the wires
Step 2: Program It
I used the example code with the Arduino IDE but if you don't have it's below!
#include
Servo myservo;  // create servo object to control a servo
int potpin = 0;  // analog pin used to connect the potentiometer
int val;    // variable to read the value from the analog pin
void setup() {
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
void loop() {
  val = analogRead(potpin);            // reads the value of the potentiometer (value between 0 and 1023)
  val = map(val, 0, 1023, 0, 180);     // scale it to use it with the servo (value between 0 and 180)
  myservo.write(val);                  // sets the servo position according to the scaled value
  delay(15);                           // waits for the servo to get there
Step 3: Test It Out
It should now work, plug it in and move the POT around the servo should move with it YAAY! Hope you liked it!
If you have any questions just leave them in the comments and I will try to answer them!
Watch The Video
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
