How to Control an RGB LED Strip - Arduino Tutorial
19,538
168
8
Posted
Introduction: How to Control an RGB LED Strip - Arduino Tutorial
In this tutorial we will use one strip with 8 RGB LEDs with the Arduino uno board. We will use the Adafruit's NeoPixel library to change the color of each led.
Let's get started!
Step 1: What You Will Need
For this project you will need:
  • Arduino uno
  • RGB LED strip
  • 3 breadboard cables
Step 2: The Circuit
The connections are pretty easy, see the above image with the breadboard circuit schematic.
Step 3: The Code
Here's the code, embedded using Codebender!
Try downloading the Codebender plugin and clicking on the "Run on Arduino" button to program your Arduino board with this sketch. And that's it, you've programmed your Arduino with this sketch!
Press the "Edit" button and:
  • change the color of LEDs at lines 16 to 18
  • change the brightness of LEDs at line 23 "pixels.setBrightness(value 0-100);"
  • change the delay time at line 32
Step 4: Well Done!
You have successfully completed one more "How to" tutorial and you learned how to use an RGB LED strip with Arduino!
I hope you liked this, let me know in the comments.
There will be more of them, so make sure to click Follow button!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
7 Comments
I was able to make this, and it was easy. However, I have to pair it with a uv sensor. How do I set the LED stick for output? Thanks!
Nice overview. Just be careful that you don't connect a second strip. It would draw too much current (arduino is rated at 200 mA). This could easily be solved with an external powersupply. Maybe mention this in the instructable, we don't want fried arduinos ;)
I think 200 ma is the max for the GPI/O pins. USB ports can generally provide 500ma of power which would be used by the LEDS. It appears as if the LEDs are powered by the 5 volts, and are controlled by a GPI/O pin, meaning that there isn't a significant load on the GPI/O pin. If you power the Arduino from another source (barrel jack, or VIN pin), you can source 1-2 amps.
Guys If want to buy some electronics stuff then visit this fb page https://www.facebook.com/hamzaelectronics12?_rdr
I'm using 30rgb LEDs (ws2812b) in a strip and the uno is doing quite well for last six months or so.
This highly depends on how you provide power: via usb from a pc, usb from battery bank or wall power, via Vin pin or via the power plug. Just be careful.
