How to Convert a 24V scooter to 36V - Dirty Method
Step 4Wire Up Good Scooter
Here is where it gets tricky... It's highly likely that your connectors will not match -- mine didn't. The best way to go about this is to start with one connector. See if both sides mate. If they do, more on.
If Not - check the other side of the connector on the other scooter. Then remove the pins from the connector and do a Frankenstein swap. The pins usually have a small tap inside - push it to the side with a small screw driver, then pull the wire/pin out.
Sometimes, there's no remedying it. In cases like these -- you can jam the pin on the wire into the connector, then secure with tape. Be sure they won't short inside the tape as these motor controllers are rather sensitive :/
You absolutely need to connect the following items
1. Hall Effect Throttle
2. Motor
3. Battery
For safety you should also connect the brake switch.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
313
Author:trebuchet03
I'm an Engineer in San Francisco. Mass producer. Former Intern. Rapid Prototyper. Sometimes, I post Instructables. My Favorite number: 42 By profession - I am an energy engineer. I count electrons p...
more »
