Step 7Power On and fly!
When you wire everything together -- connect the battery second to last, and the power switch last. It's also probably a good idea to do a "dry run"-- without the motor connected to the rear wheel (VIA chain).
Before powering on, make sure all connections are tight -- and insulated. The last thing you want is to accidentally short something.
Once your dry run is successful -- load everything into the scooter. I taped on my ammeter so I could monitor current flow
Results? Yes.
It's faster -- but it was a little slow to accelerate. My front tire has a leak, that keeps getting bigger. So that didn't help. But truly, much faster than the 24V variant I was running before :D
Proof of concept:
1. 24V motor appear to take the extra strain - likely shortening their expected lifetime
2. Gel Cells aren't too sensitive to Charging at 1.5A (just make sure the temps stay low)
3. This can be done within a few hours (except charge time - you'll want a bit longer)
Yes, I've been bit by eFever... I've always liked it, it's just reaching critical mass methinks.
Add Comment
