How to Convert Barbie into Wonder Woman!
Step 2We are here to mourn the dyeing of blond hair...
Contestants one and two need to lose the golden tresses and make way for Wondy's beautiful black mane. Barbie hair is synthetic and non-porous, meaning it probably won't hold on to human hair dye, or might even melt under it. Searching the internet, I only found a couple easy methods of color altering: permanent marker and acrylic paint. Both methods might make the hair stiffer, but let's give them a shot.
I used the ballerina for permanent marker coloring. Basically, you take a black Sharpie and color the hair from root to tip. Having hair clips of the banana variety helps to separate each row of Barbie's hair. This process is extremely time-consuming. Be careful about the fumes; don't get dizzy. Other downsides: The hairs you can't help but miss give her a graying hair look; the hair's texture is "sticky" and stiffer; it's easy to get smudges on the body. Oh, and the odor doesn't go away. I have a feeling shampooing to remove odor would lessen hours of coloring, so I'm not going to try.
Anyway, let's try the watered acrylic paint method on the dog-walker using these directions here. I didn't use Liquitex brand acrylic paint, and I used a fine comb instead of a flea comb. I much more strongly suggest this method of dying hair. For one, her hair is fairly soft afterward, and no odor! The downside is that the black is a little silvery. This contestant is a more "mature" Wonder Woman, okay? Also, if you want to try to achieve the blue-black hair she sometimes has, you might try mixing in some blue, or coloring an additional time.
For the teacher with dark hair, I decided to change her straight hairstyle. Wonder Woman has voluminous waves. The remedy: foam curlers and spraying with water.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:transplendent
