How to Convert Barbie into Wonder Woman!
Step 4The clothes make the Wonder Woman.
It's time for the most important part: the outfit. I've honestly never before made clothes for Barbie or any other doll, so I'm nervous as to how this will work out. For now, let's focus on the "strapless bathing suit" without accessories. We need red fabric, blue fabric, and some sort of gold fabric. My gold fabric was a wide ribbon.
The outfit I made was three pieces: red tube top, blue briefs, and gold belt. I first started with the top. The best way to achieve the right shape is to take the fabric and wrap it around Barbie's body. The top of her outfit has two humps over her boobs with a point in between for the W. Draw the final edges you want on top of the fabric while it's wrapped. An important idea before cutting anything: Edges fray, so cut at least 1 cm of extra fabric to fold back and sew a hem. In the back, I sewed a small snap button. You can also use Velcro, but make sure you sew it down well. For the double W logo, I used a gold paint pen by Krylon and drew it on as best as I could.
For the briefs, the steps are similar. It helps to know what kind of flat shape folds into 3-D. In the picture below, the top arc is where her waist goes, the right and left flaps fold back, overlap over the butt, and are sewn to the bottom of the middle flap at the crotch. Remember about the hemming rule, still. Also, I did not sew much of the flaps together over the butt because then the briefs could not be pulled on and off. Keep checking that you can do this as you work. I used Velcro to finish this piece. For the white stars, I decided to glue on regular white paper. I went into Microsoft Word and printed off a bunch of stars (Alt-0171) in size 18 pt in the font face Wingdings. I used the font format tool Outline, so it printed white stars outlined in black. Then I cut each out carefully using an X-acto knife and glued thirteen onto the front of the briefs with school glue, using a toothpick as an applicator. It might not hold up to rough child's play, but it holds better than you might think. I didn't put stars on the back of the briefs, but it's up to you.
I made the belt from a gold ribbon about 2.5 cm wide. Because the material frayed quite easily, I put tape across the backside before cutting. I then cut curves into the sides, leaving two points across from each other in the middle. The rest of the belt I left about 1.5 cm wide. Where the ends overlapped, I sewed another snap button.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:transplendent
