How to Convert Brainsight Custom Skull Surface (.stl) File to Autodesk Inventor (.ipt) File
1,199
5
Published
Introduction: How to Convert Brainsight Custom Skull Surface (.stl) File to Autodesk Inventor (.ipt) File
Follow those steps to convert Brainsight custom skull surface (.stl) file to Autodesk Inventor (.ipt) file
Step 1: Load STL Into MeshLab
Drag the stl file into the screen
Step 2: Delete Unwanted Faces
1. Click "Select Face in a rectangular region" icon
2. Use control, alt and mouse to select all unwanted faces*
*You may need to un-click "Select Face in a rectangular region" icon to move to different viewing angle and click icon again to select remaining unwanted faces
3. Click "Delete the current set of selected faces" icon
Step 3: Inverting Faces
We need to Invert remaining faces
1. Go -> Filters -> Normals, Curvatures and Orientation -> Invert Face Orientation
2. Click Apply and Close
Step 4: Surface Reconstruction
1. Go -> Filters -> Remeshing, Simplification and Reconstruction -> Surface Reconstruction: Poisson
2. Set Octree Depth to 7 or 8 and Solver Divide to 8
3. Click Apply and Close
Step 5: Surface Simplification
1. Go -> View -> Show Layer Dialog
2. Un-click "Eye" icon
3. Click to select "Poisson mesh" (it should highlight this one only!!!!)
1. Go -> Filters -> Remeshing, Simplification and Reconstruction -> Quadric Edge Collapse Decimation
2. Set Target number of faces to 1000*
*You can set this number higher if your computer has dedicated GPU, otherwise your computer performance will suffer.
Step 6: Export, Save As...
1. Go -> File -> Export Mesh As...
2. Set file type as .DXF format
3. Click Save and OK
Step 7: Import to Autodesk Inventor
On Autodesk Inventor:
1. Click "Open"
2. Choose file type: DXF Files(*.dxf)
3. Click "Open"
1. Click Next -> Next ->
2. Make sure you choose all the options as same as the red box I have
3. Click "Finish"
Step 8: Stitch
1. Click "Stitch" icon
2. Select part
3. Click Apply and Done
Step 9: Save As...
Click Control+S (Save as)
Choose file type: Autodesk Inventor Parts (*.ipt)
Click "Save"
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    Thanks for providing steps on how to do this!
