How to Convert Your Old Adapter Into Usb Charger
Published
Introduction: How to Convert Your Old Adapter Into Usb Charger
About: I am a student of BSCS but I'm interested in electronics that's why I would like to think about innovative ideas and try to build my ideas into reality and i also interested in making a robots. email id: deg...
Hello! friends
Welcome to my another 2k16 "Old adapter into usb charger" project. In this project i'm gonna show you how to reuse your old adapter into a usb charger for your smart phone. Actually, I just throw my adapter into a trash than suddenly I got an idea of USB charger so I pick it up again and make my own USB charger, it's really useful for me. Don't worry if you don't have your own charger follow the steps carefully and you'll be able to make your own USB charger.
So, let's get started.
Step 1: Materials
You'll need
Old Adapter (5 volts)
Female USB connector
Jumper wires
Soldering iron with solder
Glue gun
Screw driver
Plier cutter
Mini grinder
Step 2: Circuit Diagram
With the help of this diagram we can build our own USB charger read it carefully make sure pin configuration of female USB connector is same according to the diagram.
Female USB connector pin configuration
Pins Name Description
1 VCC +5v
2 D- Data -
3 D+ Date +
4 GND Ground
Actually we need only two pins 1 and 4 only for our project so skip the pins 2 and 3.
Step 3: Testing
Before using the adapter for your project make sure you just check the voltage by using DC voltmeter.
Step 4: Disassembling
Take your adapter and open it by using a screwdriver. Cut the both wires I/O an AC source as well because we need to make space for the female USB connector.
Step 5: Marking
Now put the female USB connector on an adapter case where you want to place it and then marking on it.
Step 6: Making Space
Now cut the marking piece by using mini grinder very carefully for your female USB connector.
Step 7: Soldering
Soldering the +ve side of the adapter to pin 1 of the female USB connector and -ve goes to the pin 4 of the female USB connector then attach the AC wires as well back to the adapter where you get it off before.
Step 8: Installing
Now install the all parts into the adapter case by using hot glue. Now your USB charger is ready to use.
Step 9: Finish
Attach the one end of the datacable to your USB charger and the other end into your smart phone. As you can see that charging status is clearly shown in the pictures. It means your charger is ready to charge your devices.
I hope you guys like it.
    • Spotless Contest
      Spotless Contest
    • Casting Contest
      Casting Contest
    4 Comments
    U need to choose an adapter with an output of 5V 2/2.1 A or it ll be a waste of time :)
    its a 5 volt 2 amp adapter lolx read it carefully
    what i ment bro is that it's useless to choose a less amp adapter thats all , good work :)
