loading
Step 4: Sewing tips for your new jeans
This part is kind of up to you, it will be an exact reversal of how you took the pants appart and the reason  you took notes as you did the deconstruct process.   This part is best worked in small steps because it can really be overwhelming if you are new to this.  Also, it is much easier to do as much as you can while each piece is still flat.
I don't know exactly how your garment was constructed so I will give you the probable order for reconstruction, but you will have to refer to the pieces you have removed and the half that you kep for reference.
1.  Make the zipper placket, set aside.
2.  Make your front pockets.
3.  Sew a long thin strip to use for cutting belt loops, cut belt loops to size and set aside.
4.  Sew the front pockets to the front pant legs.
5.  Attach the zipper placket and sew the front seam.  The front seam is the portion under the zipper to the crotch, probably only a few inches long.
6.  Make your decorative stitches on the back pockets.
7.  Turn in edges of the pocket, press and sew.
8.  Sew the back pockets to the back of the pants.
9.  Sew each back yoke portion to the back pant leg portion.
10.  Sew the back seam, this is the seam from the waist to the crotch. Where the yoke meets the pants section will be thicker go slow and have a sharp needle, this will be one of the thickest seam sections.
11.  Sew the outer leg seams.  Where the front pockets attach will be thicker go slow.
12.  Sew the inseam.  Matching the seams at the crotch.  This is the longest seam you will make and where all the fabrics meet at the mid crotch go slow.  Go slow and make sure your needle is sharp.  You may need to press and even hammer the fabric to compress it a bit before you sew.
13.  Place belt loops.
14.  Attach waist band.
15.  Fold up belt loops attach.
16.  Top stitch the waist band.
17.  Attach the jeans button and make button hole in waist band.
18.  Hem
19.  Wear your amazing new best jeans you ever had in the world and brag about it.
20.  Now that you know it is not so hard, keep the original pieces for your next pair, repeat as desired.
<p>This is my first time ever sewing something and I really want to copy my favorite pair of jeans, but I don't want to take them apart. They are still wearable, I don't really know some of the terms you are using in the explanation and it got really confusing for me in the middle of the explanation. I'm only 17 too, so I'm still learning; or just starting to learn at least. </p>
<p>Hi Cherryboms123456789,</p><p>Sorry I have not been on this site for a while. Thanks for your interest in my post. This instructable was written for someone with intermediate to advanced sewing skills. I would suggest that you might purchase a pants pattern, maybe even with elastic waist, for either pull on shorts or pajamas first, to begin building your skills. Then move up to something with a zipper fastener, then to something with a back yoke before you try jeans. Sewing can offer very big rewards, but it can also be a very big disappointment if you jump in too far ahead of your experience level. </p><p>Many of the commercial patterns labeled as &quot;easy&quot; are still very stylish, without the added complex seems. Good luck. I wish you every success with your newly found sewing hobby.</p>
Lots of great tips! I've been wanting to do this for a long time. I need to build up the courage to rip a pair apart. :D
Pick a pair that you have just loved to wear so much you have worn them out. If you can't wear them any way, because you have worn them out, then you will not lose anything by taking them apart, and the new pair will feel like the original.
About This Instructable
8,878views
50favorites
License:
Bio: Life is short. Create lots of pretty and useful things. I spend a lot of time sewing. I sew mostly clothing, including costumes, casual and ... More »
More by Mama Reni:How to Copy a Garment that Fits Perfectly Without Taking it Apart How to shorten pants with cuffs How to Make Cloth Napkins
Add instructable to:
