Step 6Tips and Tricks
-EXT IN A/EXT IN B can be mapped to midi features as well, but if you want to use external sources you must select Input Select and assign the proper deck.
You also need to set the Input Routing in Traktor Pro. Select BCD3000-1 in the left channel and BCD3000-2 in the right channel of Input Channel A. If you want to use the Inputs for B, route them though with 3&4.
-Knobs & Faders: The Tempo faders need to be inverted by default. Analog work smoothest.
-Jog Wheel Types:
(7Fh;01h) is faster, best for scratching.
(3Fh;41h) is finer, better for browsing.
-To have a LED light only when held set:
Controller Range Min = 1 Max = 7
Midi-range Min = 127 Max = 63
Check Invert
-To have a Led light blink with the beat:
1.Click "Add"
2.Select "Output"
3.Click on Beat Phase Monitor
4.Assign the deck
5.Select the corresponding CC
-Join the BCD Fan Forums and share your tips
http://raritiesvault.net/bcd3000
Add Comment
