3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Create an Affordable Mascot Head
Step 2Cut Rough Shapes
Cut Rough Shapes
Cut the board into ovals, or circles, or whatever the shape of your mascot head. There are many ways to cut the board such as razor blade, keyhole saw, and jig saw. Any type of saw will make a mess. The easiest, cleanest and fastest way is with a hot knife. The store bought hot knives are expensive and flimsy. I made my own following the instructions at instructables (Hot-Knife-for-Plastic-Cutting!). Instead of hammering the soldering tip, I bought a three inch long brass screw and hammered/filed it flat. It worked great. As you cut the layers try to get the rough shape of the head. IMPORTANT  if the piece is too big it is easy to make it smaller, if the piece is too small it is very hard to make it bigger. When you cut the first pieces, make them bigger than you think you need them. Another tip is to number the pieces, label the top and bottom. That way it is easy to put them back together in the correct order.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:edgukated
