How to Create a Batch File
642
6
Posted in TechnologyComputers
Introduction: How to Create a Batch File
About: M DeMers Senior Director of Fuel Ignition Division Jet Propulsion Laboratory 4800 Oak Grove Dr, Pasadena, CA 91109
Batch files are sort of like a "forever saved" command prompt but with more commands. The file type is ".bat" Batch files can be used for password lock on files, calculator, simple animations, and much much more. Only works on windows
Step 1: First Open Notepad
First, open notepad. Word pad does not work.
Step 2: Write the Script
Here's the hard part. Actually writing the script. Find a list of ever signal command a their description here.So once you have an idea find the right commands to carry out your idea. Some commands have variables (ie attrib) So then layout the commands (each command on a separate line going from up to down in order) in note pad. I will be making a simple Echo (text) command. As you can see all commands are in CAPS. Also make sure to put in,pause if you don't want the command closing right after opening.
Step 3: Save As an Batch File
Now in the top left corner click file then save as. Locate the folder you want and name your file anything you want. BUT WAIT before you save, where the file says ".txt" (no quotes) delete that and replace that with ".bat" (no quotes.) and your done! To start up the command just locate the file and click on it. Depending on what you set it up to do it will most likely carry that out. if you have any questions ask ask in the comments
Step 4: Open the .bat File
Open the file and the file (depending on the script) will start.
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
