loading
Step 1: Making the First Round - From Slipknot to Joining
Make a slipknot with your yarn and insert the hook into the knot.
Chain 4 stitches.
Insert your hook into the first stitch (closest to the slipknot).
Yarn over and pull the yarn through the stitch. Slip the stitch through the loop on your hook.
This creates the ring (center of the granny square). Take note of the hole in the center of the ring, this is where all the work will be done for the first round.
Chain 3 stitches.
Double crochet into the ring
Double crochet into the ring again.
This set of stitches is the first "shell" of the granny square. A shell consists of three double crochets together in the same space. Please note that the chain of 3 takes the place of a double crochet.
The first round will consist of four shells. You will need to chain 2 stitches between each shell in the first round.
Chain 2 and make another shell by doing three double crochets into the ring (this is shell number 2).
Chain 2 again, make another shell by doing three double crochets into the ring (this is shell number 3).
Chain 2, yet again, and make the last shell for round one.
You now have 4 shells and are ready to join them together.
Chain 2 stitches then insert your hook into the second stitch of the first shell you made (the second stitch on the chain 3 we did directly after making the ring).
With your hook through the stitch, yarn over and pull through. Slip stitch through the loop on your hook.
That concludes the first round. All subsequent rounds are just a repeat of this round. The only difference is the number of shells you will make and the amount of chain stitches between shells.
I just started teaching myself tp crochet yesterday. End goal is a mermaid tail blanket for my neice. Your directions were awesome and so easy to follow. Thanks!
<p>It's not bad! I'm pretty pleased!</p>
<p>Hi russm313 . Been trying to teach myself to crochet more than 6 feet of double and triple crochets rows. Found your video by accident today and after 8 hours I completed this square! BEST help I've seen out of dozens of videos. Thanks! &lt;3 </p>
<p>I try and try and I always come up with a circle. Never a square. I add stitches, make longer rounds... nothing woks. My brain seems to be crochet-impaired :-(</p>
<p>I've been trying to teach myself to crochet, and this is the BEST tutorial! <br>I MADE MY FIRST SQUARE!<br>thankyou so much for taking the time to explain each step so simply and clearly, and for not including 20 minutes worth of useless information before and after each step. You should seriously think about starting some &quot;how to make a tutorial&quot; workshops!</p>
<p>I haven't crocheted in over 20 years. This is my second attempt at the square. Once I sorted out the hook size I felt much better. Pretty happy with the result. Thanks for the easy to follow instructions</p>
<p>Thanks so much for the GREAT instructions! I'll look forward to whatever else you choose to explain. This made learning the granny square a snap!</p>
<p>Phew! Thanks! It's nice to learn how to do the basic building block of any blanket project. </p>
<p>I've been crocheting for more years than I want to disclose:) My grandmother taught me as a child the basic stitches. I've recently picked up my hooks again in an attempt to make a sunflower granny square. I've read and watched so many books and tutorials that I was way too confused and gave up. I watched your video and read the instructions. You're a crocheting master! The instructions were clear and concise. Your voice is very soothing too! THANK YOU for sharing your talent!</p>
<p>Does the hook size matter? I prefer to use a J hook but I'm afraid it may be to big.</p>
<p>Thanks, found this really helpful. I find it easier to follow written instructions and photos than v&iacute;deos. Thanks again!!</p>
<p>thank you, this is so easy to follow. The first one went a little wrong but the 2nd came out fabulous but I'm not finished with it yet, thanks again :-)</p>
<p>Thank you SO much!! I am a knitter who could never figure out crochet. I have spent the last couple of days making a couple of granny squares, pulling them out and beginning again after looking at instructions...not yours, but in ebooks. While I learned each stitch, instructions for the granny stitch were not quite complete enough. For instance you showed which hole to use, you pointed out when to chain specific amounts and why. With other's instructions I kept getting only three shells. I knew it wasn't right, but kept going. Got some funny looking ones!</p><p>Perhaps this is why so many of us have had trouble with crochet. Anyway, I appreciate your help and the time it took to make your instructable.</p>
<p>thank you so much. my friend showed me this pattern a few years ago, but I had lost the pattern and lost touch with my friend. JUST like the one she showed me a few years ago !!</p>
I've completed a 17by 17 granny square ,but it's a bit rippled :( .What would be the best method to make the square flat and even . Thanxs
<p>I think you forgot that you have to slip stitch 3 stitches to get to the first opening in round 2 before the 3 chains.</p>
Excellent video ~ many thanks !
<p>what is your YouTube name? These are the easiest to follow videos!</p>
i made it :-) my blanket is growing :-D
<p>Thank You!</p>
<p>Thank you! Excellent and very easy to follow instructions. </p>
only just started was just practicing the basic stitches now I'm on my way to making my own blanket thanks for sharing great instructions simply and easy to follow :-D
One of the best instruction on how to crochet a granny square that I've ever seen! Great video and great step-by-step instructions! Had I seen this when I was first learning how to crochet a granny square, I would have understood the process immediately! Great job on both video and written instructions!
This tutorial has got to be the best ever presented and/or published. Thank you for going slow and showing each step so clearly. This has been a tremendous help
Thank you very much for saying so. It's always nice to hear that I was able to help someone. :)
Thank you! This actually makes sense! Other explanations made me feel like an idiot.
Thank god! Finally a granny square pattern I can understand!
Thank you so much for these easy to follow instructions, I have tried many different websites and utube instructions but these are by far the best. I am now well on may way to making a granny blanket :-) <br>
Wonderful. I am trying my best to do a Granny Square. I have the wool, I have the crochet hook, I have my hands and I have your instructable. It can't be so hard now, can it?<br>Here I go.........<br><br>
I've attempted learning to crochet before, but no dice. Thanks to this Instructable, I can now make granny squares! Thank you very much!
I've never crocheted before, but your step-by-step pictures make it look so easy! I'm definitely going to try this now that I have clear instructions on how to crochet. Thank you for the help! &lt;3
That sounds great! Please let me know how it goes and if I can help along the way.
&nbsp;made 2 squares today. 138 more to go.
Awesome!&nbsp; Hope they go well.<br />
Thank you I never understood where you inserted the hook to join :) now I know Thank you very much :)<br />
I am very glad it was helpful.&nbsp; You are welcome.<br />
Years before I was born, my grandmother made a whole double-bed sized blanket out of these squares - she made them with scraps (she did a lot of knitting), so every square was different.<br /> <br /> I still have the blanket.<br />
I&nbsp;love stories like that. &nbsp;I bet it is a unique blanket, for sure.&nbsp; I will have an instructable coming soon on a creative way to use these squares.&nbsp; <br />
It's really warm over a quilt, but it weighs a ton, which Kitewife finds uncomfortable.<br />
About This Instructable
802,520views
377favorites
License:
More by russm313:Star Trek Kindle Cover Legend of Zelda, Triforce Pillow iPhone mount for telescopes
Add instructable to:
