Step 4Making the Beard
With hat facing you, you will have 6chains connecting the hat.
Count 9stitches right side (mark) and 9stitches left side (mark)
17: Starting on the right side (hat facing you upside down) join with a sl st to 10th stitch, ch2,(does not count as first hdc), hdc in next 9 stitches, hdc in the 6 chains, hdc in next 9 stitches, ch2, turn
18 - 20: hdc in each st across, ch2 turn
21: hdc2tog, hdc in each of the next stitches, hdc2tog in last two stitches, ch2, turn
22: hdc in each st across, ch2, turn (22hdc)
23: hdc2tog, hdc in each of the next stitches, hdc2tog in last two stitches, ch2, turn
24: hdc in each st across, ch2, turn (20hdc)
25: hdc2tog, hdc in each of the next stitches, hdc2tog in last two stitches, ch 2, turn
26: hdc in each st across, ch2, turn (18hdc)
27: hdc2tog, *1hdc, hdc2tog* Repeat across, ch2 , turn
28: hdc2tog, hdc in next 8 stitches, hdc2tog in last two stitches, ch2, turn
29: hdc in each stitch across, ch2, turn
30: hdc2tog across, ch1, turn
31: sc2tog, 1sc, sc2tog in last 2 stitches, ch1, turn
32: *sc2tog, 1sc* repeat across, ch1,
Working in edge sc in each stich around the bottom of the hat. Finish off weave in loose ends
Working in the edge of 'face' sc in each stitch around. Finish off weave in loose ends.
Add Comment
