How to Customize Your Snowboard
21,038
13
Posted
Introduction: How to Customize Your Snowboard
Tired of your old snowboard but don't have the cash to replace it? With under $20, you can breath new life into the look of your board with a custom paint job! Follow these easy steps and you'll have a new board (or at least look like it) in just a couple days.
Step 1: Setup
Plan your design. You could go as simple or as creative as you want. I went with two parallel pinstripes that run from the front of the board to the back - very easy and it looks cool.
Place your board on a surface that you can get paint on. This could be a work table, a basement floor with rosin paper, etc. This job can get messy as you want to get a heavy coat of color on the board.
Buy the following products:
Plasti Dip Rubber Coating (1 can, black)
Acrylic Lacquer (1 can, new board color)
Masking Tape (1 roll) (optional)
Stomp pad (1)
Step 2: Remove the Bindings
Remove your bindings. You will likely need a screwdriver for this.
It is very important that you write down or mark the location and rotation of your bindings as you remove them. These are often set in place by professionals and you don't want to mess with your snowboarding comfort level for new paint job - no matter how sick it looks. I usually use a few pieces of masking tape under the areas where the bindings are.
Step 3: Apply Rubber Coating
Apply 2-3 even coats of rubber coating with drying time in between coats. I used Plasti Dip's black rubber coating and it covered well.
Step 4: Apply Laquer
Once the final layer of the rubber coating has adequately dried, now it is time to get ready for the final paint color. If you want to add black stripes as I did, you'll want to mask out those spots with the masking tape.
Now, apply 3 coats of Acrylic Lacquer. I used Dupli Color's Acrylic Lacquer in silver. It has a nice metallic finish and covers well.
Step 5: Remove Tape
Once the coats of lacquer have been applied and the final coat is dry, remove the masking tape.
Step 6: Re-install Bindings
Put your bindings back on with the screwdriver. Make sure they are aligned in the identical configuration as you previously had them.
Step 7: Install Stomp Pad
If you prefer to have a stomp pad on your board, install it at this point.
Step 8: Bask the Glory
Place your board on a well-lit shelf and bask in the glory of its sick new paint job.
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    3 Comments
    Could you use flex seal for the rubber coating?
    What I'd do, I would place lots of masking tape on the board and add colour, but an awesome job! I'm going to do this to my board soon! Thx!
    Not bad, but the design is a little boring. Still it's better than what it used to look like :P lol
