3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Cut Down a Tree
Cutting down trees seems easy, and it can be, but if you don't do it right it can be dangerous and time consuming. A friend of ours had a tree that was rotting and needed to be cut down, so we offered to help. I figured it was a perfect opportunity to write an instructable!
This instructable is meant to help you cut down a tree safely and correctly, but chain saws and falling trees are inherently dangerous. Practice caution whenever attempting to cut down a tree. Do it at your own risk. You alone are responsible for any damage that results from a tree removal gone wrong.
This instructable also assumes previous knowledge about the use and safety practices associated with chainsaws. If you do not know how to properly handle a chainsaw, either learn from an experienced operator or hire a professional to cut your tree down.
Step 1Supplies
  • At least one chainsaw, it's nice to have two (more on that later)
  • Gloves, preferably leather
  • Safety Glasses (you really do need these, my dad had to go to the ER once from a splinter of wood in his eye)
  • Friends
You also may want:
  • Leg protection
  • Ear protection
  • Boots
Member morfmir also has this to say about safety equipment:
"The most imported thing are protection pants. Always ware them when using chainsaw. Cutting wood can be unpredictable, if the saw slips into your legs it can be deadly. The safety pants stops the chain before it cuts into you.
Helmet, my helmet have saved me from falling branches more than ones. When you start to cut, dead and dry branches from the top of the tree can get lose and fall to the ground. When your concentrated on the saw you don't see the falling danger. And if it is a big branch it can cause serious injury.
Safety boots. freshcut wood are very heavy, if you get the log over your feet if will crush it. Next it will also protect your feet and toes from the chainsaw.
Ear protection, chainsaw are very noisy you will lose your hearing if your don't ware ear protection. Most helmets have build in hearing protectors.
Gloves and eye protection. This you already have, that's good. If you use helmet most of them have a face screen that protect the face and eyes. Plus it will not get misty in bad weather like glasses."
32 comments
Nov 1, 2011. 3:57 PMrjohannesburg says:
After reading all these comments, I think the safety pants are a really good idea. Also, the advice to always fell a tree with someone else there is a really smart idea. But the best idea is to hire a professional to do the tree removal. Especially if you know nothing about felling trees. It's definitely not for beginners, and one instructable isn't going to be enough to do it safely.
Jun 16, 2009. 12:04 AMevan_124 says:
what i would really like to see is a good instructable about how to remove the trunk and root ball easily after you get the tree down for those of us who cant afford a big trunk grinder or pros to come and tear it out for us
Oct 17, 2011. 4:32 PMbricabracwizard says:
Thanks, just knowing there is such a thing as stump remover! Grinding out stumps is expensive!
Oct 17, 2011. 6:34 AMcheapasdirt says:
Warning: Attempting this instructible is dangerous and not recommended. Numerous points contained here within are incorrect and should not be attempted.
Attempt at your own risk.
May 15, 2010. 1:51 PMQCtreeclimber says:
DON'T DO THIS WITH OUT THE PROPER PERSONAL PROTECTIVE EQUIPMENT!!!!! CHAPS, SAFETY GLASSES GLOVES HEARING PROTECTION AND BOOTS (PREFERABLY LEATHER WITH STEEL TOES).  NEVER NEVER NEVER  DO THIS IN SHORTS!!! THIS IS WRONG!!!!
Oct 10, 2010. 4:12 PMhifatpeople says:
YOU DONT NEED TO USE ALL OF THAT!!! JUST USE AN AXE AND COMMON SENSE AND YOUR GOOD TO GO!!!!!!!!! WHY ARE WE YELLING?!?!?!?!?!?
Sep 9, 2010. 4:10 AMsuryachalla says:
Dear Mr. Weissensteinburg,
I knew nothing before this about the dangers involved in "tree felling". From the comments I've read above, it seems that you have taught us a lot from what you have left out of your article, rather than from what you have written!
Granted you might be a "pro" for whom trees are second nature, but when you're instructing, it should show your professionalism by going to the "grass roots" or "basics".
May 15, 2010. 1:47 PMQCtreeclimber says:
There are so many things wrong with this instructable.  I have no idea why homeowners always want to make an angled back cut. This is WRONG.  I climb prune and remove trees everyday, I use a chainsaw on a daily basis and what you have done is Horribly wrong.  First of all you should never do this in shorts, you need to wear chaps hearing protection and boots in addition to your safety glasses and gloves.  NO ONE SHOULD ATTEMPT THE INSTRUCTIONS HERE, THEY ARE WRONG AND YOU CAN KILL YOUR SELF OR OTHERS!!!! HIRE A PROFESSIONAL, ITS CHEAPER THAN A FUNERAL!!!!
Aug 16, 2010. 5:04 PMquadracer says:
Thanks for pointing this out. I work at a saw shop and I dont even test saws with out chaps, glasses/steel toes and gloves, let alone when im falling trees. Never drop trees alone people.
Jul 16, 2009. 5:18 AMalphaman1101 says:
Look in the background i dont think your neighbors are too happy with you :P lol
Feb 9, 2009. 12:09 PMlemonie says:
I love chainsaws And would like to add that (in the interests of safety) they should not be used while under the influence of alcohol or drugs, or in poor light. L
Dec 30, 2008. 10:18 PMs666666666666 says:
If anyone is considering felling a tree and has any questions or even the slightest amount of doubt in their ability. I would either A - look up any info you can until you're comfortable, or B - get a professional to do it. Here in British Columbia, Loggers that fell trees actually have to get certified. So obviously there is a bit more to it then cutting a wedge and a back cut. Possibly mention in the instructable about "kickback" and what it is and how to prevent it. I work at a Stihl dealer and have seen a few guys with pictures after their kickback incident. Also you should use the chainbreak whenever you're not going to be cutting or when you're walking around with the unit running. The chains are extremely sharp. There was one guy who touched his leg with the chainsaw while it was idling. Didn't notice till he got in the house, leg felt warm and wet, poured the blood out of his boot and went to the hospital. On a lighter note. good general instrucable and if anyone wants to see some cool videos. check youtube for tree felling or falling tree etc etc. There are some MONSTERS that come down.
Dec 28, 2008. 1:16 AMmorfmir says:
I like your effort, and the overall instructable are well written. But your instructions are faulty from start to end. You will kill your self or some other if you don't take safety serious. Falling trees and chainsaw are not toys and can be deadly if not handled right. very, very, very bad idea to cut down a tree without any Safety. Please remove this instructable, or make a BIG remark that this is the way NOT TO CUT DOWN TREE. /Thomas
Dec 28, 2008. 10:59 AMmorfmir says:
You have to thing more about safety. Specially personal protective wear.
/Thomas
Dec 29, 2008. 2:37 AMmorfmir says:
That is fine, glad to help. An glad you did not injure your self. /Thomas
Dec 28, 2008. 4:55 PMblugyblug says:
I seriously hope there won't be a tree hugger comment. There will be one inevetibly though... Ah well.
Dec 29, 2008. 1:43 AMblugyblug says:
Yeah we had to cut down the branch of a tree because it was hanging over our driveway.
Dead trees make good firewood. Since they are dead, they dont't absorb moisture and are dry...
=good firewood.
Dec 28, 2008. 12:10 PMreedz says:
I really like this, it is pretty informative. Perhaps you could add a note: Trees generally fall in the direction you want, however if a tree is already leaning or has a lot of branches on one side it is more prone to fall that way. Otherwise, 4/5
Dec 27, 2008. 11:41 PMpbonk says:
I'd suggest a few more pieces of safety equipment:
- Helmet with face shield and hearing protection
- Leg chaps and long pants
- Steel toed boots
More info here, safety gear
Dec 27, 2008. 9:02 PMGorillazMiko says:
Look at dem nosy neighbors..
Dec 27, 2008. 8:51 PMNachoMahma says:
. Good job.
Dec 27, 2008. 8:06 PMLinuxH4x0r says:
Nice. I personally prefer the *relative* safety of using a reciprocating saw with a 12" blade.
Dec 27, 2008. 7:17 PMbumpus says:
Warning! Get really drunk first. Then it won't hurt so much when you chainsaw your face off and crush your family. - Tim Anderson.
:D
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
151
Author:Weissensteinburg
I enjoy photography, horticulture and carpentry, and am almost always doing something relating to of those things. Feel free to send me a PM for whatever reason.
