Introduction: How to Cut Your Own Sidebangs
Welcome to my tutorial! The goal today is to take dull, drab hair and transform it with some sassy, flirty sidebangs. This super easy method takes all of five minutes, but here I’m going to break it down for you, along with some helpful side notes and other options.
Materials Needed: Comb, scissors, clips, mirror, some hair, flat iron/straightener (optional), water bottle (optional).
Preparation: Part your hair down the middle. If you are cutting it wet , make note of your natural texture. Curly hair should be cut longer than desired, otherwise you’re going to have itty bitty curlies right on your hairline. Wavy and straight hair is fine. If you are cutting it dry , flat iron the hair you’ll be cutting. Keep in mind that this will give you more precision, but your bangs may not look exactly the same when you wear your hair natural.
Just as a side note, my mannequin is the CLiC model named Courtney.
Step 1: Create a Triangular Part
It’s important not to make the triangle’s base too wide or too narrow. Your pupil is usually a good guide, but if you’re worried, take a little less hair. You can always cut more off later, but putting it back on costs major mula. Also, don’t make the triangle too tall. If you do you’ll be cutting into your hairstyle, resulting in some serious flyaways and frizzies.
Step 2: Brush Hair to the Opposite Side You Want Your Bangs to Fall
Wait, what? The opposite? Are you sure? Yes, I’m sure. If you want your bangs to go left, brush them right. If you want them to go right, brush them left. This will all make sense in the end, just trust me.
Step 3: Twist and Cut
This step is a teensy bit more complicated than it sounds. Long story short, twist the hair towards the back of the head and cut parallel to your parting line, as shown in the picture.
Why are we twisting the hair? The shortest piece of hair in your sidebangs is the ‘axis’ the hair is twisted on. The longest piece is the one that gets twisted over. The longer the hair travels, the longer it will be after the cut.
What happens if I cut horizontal, instead of parallel? You’ll get a very sharp slant that could look kinda strange, possibly even straight up weird.
What happens if I cut it at the wrong angle? Best case scenario, you get something resembling a blunt cut bang. Worst case scenario, you make an appointment with your local hairdresser and laugh off your mistake.
Where should I cut along the length of the hair? If you want to feature your eyes, cut where my metal clip is. If you want to highlight some beautiful cheekbones, cut around where my blue line is. Anything too much higher than the clip will give you short stubbies. Anything lower will put the bangs in your eyes and draw attention to your nose, which may or may not be good.
Step 4: Marvel at Your Newfound Skill
If you cut it wet, things should be looking pretty fly. If you cut it dry, you may have to wet it down and blowdry it, depending on how unruly your hair is. That’s what I did with Miss Courtney.
Step 5: Style As Desired
You look beautiful! Take a picture and update your facebook. Feel proud as the compliments come flooding in. Courtney here is going on a date so I put her in a trendy (not a Snooki) poof and a twist. I wish I had taken a picture of the twist before I brushed her out. Ah well, hindsight is 20/20.
If you love your new bangs, want to request a tutorial, or have any questions, hit me up and I’ll be sure to answer.
