Materials Needed: Comb, scissors, clips, mirror, some hair, flat iron/straightener (optional), water bottle (optional).
Preparation: Part your hair down the middle. If you are cutting it wet , make note of your natural texture. Curly hair should be cut longer than desired, otherwise you’re going to have itty bitty curlies right on your hairline. Wavy and straight hair is fine. If you are cutting it dry , flat iron the hair you’ll be cutting. Keep in mind that this will give you more precision, but your bangs may not look exactly the same when you wear your hair natural.
Just as a side note, my mannequin is the CLiC model named Courtney.
Step 1: Create a Triangular Part
Step 2: Brush Hair to the Opposite Side You Want Your Bangs to Fall
Step 3: Twist and Cut
Why are we twisting the hair? The shortest piece of hair in your sidebangs is the ‘axis’ the hair is twisted on. The longest piece is the one that gets twisted over. The longer the hair travels, the longer it will be after the cut.
What happens if I cut horizontal, instead of parallel? You’ll get a very sharp slant that could look kinda strange, possibly even straight up weird.
What happens if I cut it at the wrong angle? Best case scenario, you get something resembling a blunt cut bang. Worst case scenario, you make an appointment with your local hairdresser and laugh off your mistake.
Where should I cut along the length of the hair? If you want to feature your eyes, cut where my metal clip is. If you want to highlight some beautiful cheekbones, cut around where my blue line is. Anything too much higher than the clip will give you short stubbies. Anything lower will put the bangs in your eyes and draw attention to your nose, which may or may not be good.
Step 4: Marvel at Your Newfound Skill
Step 5: Style As Desired
If you love your new bangs, want to request a tutorial, or have any questions, hit me up and I’ll be sure to answer.
Visit Our Store »
Go Pro Today »
I did amazing bangs and although the way I cut my hair looks amazing on me..My friend wouldn't let me cut hers so I showed her this and it looked amazing Thanks:P
