How to Cut an Obtuse Dovetail
Introduction: How to Cut an Obtuse Dovetail
An obtuse dovetail is a joint where the angle between the two parts is greater than ninety degrees (and less than one hundred and eighty degrees). In this example, the angle will be one hundred and ten degrees, but no math is used, so the method will work with any obtuse angle.
It's a little more complicated than a standard dovetail, which is at ninety degrees, but follow carefully and you'll be able to manage it.
As usual, I've filmed a video of the process for greater clarity:
Step 1: Marking for the Tail
Yes there's a lot of photos! I've tried to show every step, since this is the most crucial stage
I'm using parts which are the same width, but different thicknesses
Use a dovetail marking gauge ( to mark the slopes of the inside tail (the side that faces the obtuse angle, and won't be seen when the joint is assembled)
Mark the angle, at the end of the other part, to find the finished length across it. Use a bevel gauge set to the desired angle to one end of it's blade (this automatically sets the other end to 180 minus this angle)
Use this finished length, to mark off how far the dovetail slopes need to extend, and use a marking gauge to scribe a shoulder line for it
Using the same bevel gauge, scribe the shoulder line across the sides of the tail piece, and also at the end
Reset the marking gauge and scribe the shoulder line on the reverse face of the tail piece
Scribe a line to define the waste portion at the end
Now use a try-square to transpose the corners of the dovetail from the inside surface to the outside surface. You're recreating the same shape, but it's shifted back from the end, due to the joint angle
Join the corners up, extending the slope lines to the end of the piece
Now on the end, join the two dovetails together with lines. These should diverge from the smaller, inside dovetail, to the extended, outside one
Step 2: Cut the Tail
Saw down the dovetail slopes, following the diverging lines on the end
Now saw off the end waste
Finally saw in the dovetail shoulders
The resulting dovetail is quite distinctive, and you should find that the end is now rectangular
Step 3: Marking for the Pins
Saw off the angled end of the pin board, which was marked during marking out for the tails
Rest the tail on the end of the pin board, and mark the dovetail slopes
Mark in perpendicular lines for the pin sides. This can be tricky since the end is angled, and you can use a marking gauge to check these are parallel to the board's edge
Mark in the length of the pins, directly from the tail piece, and use a try square to scribe the base of the pin socket
Step 4: Cutting the Pins
Saw the sides of the pins, following the lines on the face and end of the board
Use a coping saw to cut across the base of the socket
Clean the base cut up with a sharp chisel
Check the pieces fit, and adjust if necessary
Step 5: Glue Up
Apply adhesive to all the mating surfaces and push the joint together
Clamp, and allow to dry
Step 6: Finish
Flush the joint up with a hand plane
That's it!
I hope you found my instructable helpful
There are many more hand cut joints shown on my YouTube channel, and more to come here on Instructables
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    Best video I've seen in many years
    Keep up the great work !!!!
    That phrase sounds like a playground insult, haha. "Oh yeah? Well YOU'RE an obtuse dovetail!"
    Very nice work on this Instructable. Good job!
    Beautifully executed and clearly explained...thanks!
    Wonderful Instructable. Good job man and well done.
    I cannot believe how enthralled I was by this video. Thanks Mitch!
    Excellent 'ible and complementary video. Good photos (well lit, good perspective and in focus). Sufficient detail and good pace to information. Very nicely done.
    Thanks for sharing your knowledge.
    Great hand skills Mitch, nice job mate
    I've rarely seen such a precise work.
    Lucidly presented
