Introduction: How to DIY a Playable Keytar With Cardboard
A Keytar perfectly combines keyboard and guitar together. So today we will make an ultralight cardboard Keytar. No matter you like musical instrument or not, you will love it!
Step 1: Preparation
Picture of Preparation
Multi-Control board - http://bit.ly/2sTJYxx
USB cable
10 x 3-pin inching switch
Pencil
Ruler
Male-to-female pin header
Eraser
Utility knife
Marker pen
Double-sided tape
Glue gun - http://bit.ly/2twpx8w
Soldering iron - http://bit.ly/2t3fPKx
Cardboard
Step 2: Draw Out a Keytar
Picture of Draw Out a Keytar
Step 3: Cut the Keytar Boards
Picture of Cut the Keytar Boards
Follow the outline to cut the board to get the first keytar board with knife. Then follow the outline of the first to cut to get another board.
Now, we have two Keytar boards at hand.
Step 4: Split the Keys
Picture of Split the Keys
Split the keys with knife along the gaps and paint the gaps with the Marker pen.
Step 5: Insert Switches to Board
Picture of Insert Switches to Board
Cut out the keyboard area of the second board, and cut some gaps for the switch, so we need to make sure the gap is the same the switch on the width.
Note: To make sure your Keytar can work after complete, you should make sure the switch position is right under each keys (that is the position should be at the center of the key)
Then fix the switches with glue gun.
And paste two boards together with glue gun or double-sided tape.
Step 6: Solder Switches to Pin Header
Picture of Solder Switches to Pin Header
Fix the pin header on the back of the Keytar board. Define keys to C, D, E, F, G, A, B, and C+ from left to right, and the keys on the neck to Ctrl 1 and Ctrl 2 as shown above.
The pin header is to connect the switches to the Multi-control as shown above: C to UP, D to Left… Align the pins on the back of the Multi-Control with the pin header, we can know the corresponding connecting sequence. Then solder the normally-open pins of switch to the pin header via a cable.
Step 7: Connect COM Pins of the Switches to GND
Picture of Connect COM Pins of the Switches to GND
Connect the pin corresponding to Multi-Control’s GND to the COM pins of the switches one by one.
Step 8: Insert the Multi-Control to the Pin Header
Picture of Insert the Multi-Control to the Pin Header
Step 9: Download the Code
Picture of Download the Code
Visit the wiki page of Multi-Control, you can see the related resources.
Click Here to download the library of the code. Click Sketch -> Include Library -> Add .ZIP Library to include library Joystick and MIDIUSB.
Then go to Github Page and download the code.
Step 10: Modify the Code
Picture of Modify the Code
The matching of Multi-Control to Switch is different from that in the code, thus we need to modify the pin’s definition.
The first picture is the mapping of Multi-Control to the Keys.
Thus we need to modify the definition like the second pictures
After modifying, select the board type and port, and upload the code.
Connect the Multi-Control to computer via the USB cable
Get a MIDI software to start your Keytar playing.
About This Instructable
844views
7favorites
License:
Bio: We're an ambitious team for developing STEM education by Arduino and Raspberry Pi learning kits as well as robots and aircraft models/drones. Happy ... More »
More by SunFounder Maker:Make a Reflex Measurement Device With SunFounder Nano Giraffe-Shaped Temperature-Controlled & Multi-level Desk Fan With NanoHow to Mount CC3D Flight Controller to Quadcopter (Assembly, Wiring, Software Configuration)
Add instructable to:
