Updated - Lightweight Shelves for Legos - Cut With the Laser Engraver
8,543
66
8
Posted
Introduction: Updated - Lightweight Shelves for Legos - Cut With the Laser Engraver
LEGOs are wonderful!
Some might say LEGOs are TOO wonderful!
My son loves them and has developed great manual dexterity by building many of them. From Fire Engines to Trains to dinosaurs, he's been having a blast. Now it's hard to store them without eating-up lots of cabinet and bookshelf space...
So one night while watching How it's Made on TV, I started dinking-around, drawing an interlocking set of adjustable shelves using Corel Draw 5 (version 15 when you save the file).
I built these out of cheap 1/4" MDF.  Fortunately Legos do not weigh a whole bunch, so I felt comfortable using 1/4" MDF.
They feature Earthquake Lips, which help keep the vehicles from rolling onto the floor...
Luckily, I've got access to a 60-watt laser cutter/engraver as a member of TechShop in San Jose, California. Check 'em out at http://techshop.ws
I made a couple of sets of shelves that can hold the lightweight LEGOs.  This main photo shows only the bottom and middle shelf backboards - putting the top shelf backboard puts the shelves out of reach - too high for my son. All the shelves shown in the picture cost a total of maybe $20.
Step 1: Get the MDF
Somehow I've developed the Mr. MDF moniker at TechShop.  Maybe it's because of the fun stuff I've been building from Cub Scout neckerchief slides to toy cranes to toolboxes to a wide variety of boxes.  I first started using the MDF as a good prototyping material for its cost.
MDF: Medium Density Fiberboard
**** NOTE! Home Depot is no longer my supplier for MDF.  ***
Check out this Instructable for more info:  https://www.instructables.com/id/-GOOD-MDF-BAD-MDF-/
I pay about $5.25 per 2' by 4' sheet of 1/4" MDF at my local big home improvement store. Home Depot works well for this stuff. Last time I measured with a micrometer, the actual thickness of the Home Depot 1/4" MDF was .236 inches.
MDF quality varies. It's worth confirming you've got a dimension that will work well with 1/4" mortises and tenons. Do some test-burning on the laser cutter/engraver before buying lots of MDF and expecting the parts to interlock well.
Cut the MDF to 24" x 18" pieces or have them cut for you at the home improvement store.
The machine you use to make the cuts will need to accept a 24" by 18" piece of MDF.
Step 2: Cut the Backboards...
Since the 3 backboard types are cut in the same manner, I will just show only one of them here.  It is the bottom backboard and has a straight bottom.
The first photo shows a rear view of the bottom backboard with the standoffs to give room between the backboard and the wall. I mounted the backboards with 6 screws each using drywall anchors.
The second photo shows a rear view of the bottom backboard without the standoffs. This makes it easy to see how each shelf slides in and latches onto the backboard.
Each backboard is about 19" wide by 16" high - this is limited by the dimensions of the Laser's table.
The Corel Draw 5 (version 15) drawing that cuts this is called BottomBack.cdr and includes 3 standoffs.
CenterBack.cdr is for the center backboard.  If you only want two interlocking backboards, it's easy to modify this drawing with a straight line at the top of the backboard.
TopBack.cdr is for the top backboard.
Step 3: Cut the Shelf Pieces... Same Procedure for Each Shelf You'll Build.
I'm providing a Corel Draw 5 (version 15) file for all the pieces needed for each shelf. This file is ShelfPieces.cdr.
The four pieces of each shelf are shown here together.
When assembling, put the Earthquake Lip in first, then the side supports.
I have used NO GLUE when putting these shelves together - the assemblies stay together well. There is a lot of surface area on the mortises/tenons which interlock.
A couple of extra shots of the shelves are here, too...
Step 4: Load 'em and Enjoy 'em...
Build as many shelves as will fit your needs. Slide them into the backboards and push them down to lock them in.
The danged laser makes it very easy to develop interlocking stuff quickly and precisely - NON-SAWDUST woodworking...
I'm finishing this Instructable up for now while relaxing with my popcorn and soda pop at TechShop San Jose.  http://techshop.ws.
Please forgive the snake!  It's a wannabe Lego!
  • Minecraft Challenge 2018
  • Epilog Challenge 9
    Epilog Challenge 9
9 Comments
this is fantastic but I could never fabricate it myself, I wonder if I could create something with the same concept with a peg board.. Thanks for sharing this!!
Maybe I should have called it "Overtly-Legoed"...
There is no over-LEGOed. No. There is only under-LEGOed...
hmm... looks a lot like my room... i do have a few more sets though! i cant help it, LEGO keeps coming out with awesome new sets! :S
I was expecting something different because of the title. Crafty, eh...
I'm going to try it with other things of little weight, thanks.
thats great! im 13 and still love legos! i have about 200 pounds of legos! XD shelves would be so helpful. (no im not a maker noob!) i do many electronics and i am a real maker!i use arduinos... i love this idea... thanks for sharing! keep it up!
Hmmmm... I'd feel good with 3 to 5 pounds per shelf.
Lego's density is not especially high, even on the larger creations, so the weight on each shelf is pretty low. I kept the depth of the shelves a bit minimal to keep any sagging at bay.
They've been in place about 2 months now, and ZERO weight/sag issues with even more Legos than shown in the pic.
TG
Hey Tom!
Cool shelves. Nicely designed. How many pounds do you think they might support?
Jim
Earthquake lip... Inspired by Mick Jagger...
