Introduction: How to Deep Clean Your Oven in 2 Easy Steps!
Deep cleaning an oven can certainly be time consuming as well as a difficult task when no matter how much force you add in scrubbing the grease & grime it just won’t come off. However, having a spot free oven definitely helps with increasing the potential sale of your home .
Forntunately, for you all I’m here to share with you guys how I was able to remove baked on hard to remove grime & grease off of the inside of my oven
What you will need:
1. Easy Off – Oven Cleaner 2. Scotch Bright – Heavy Duty Scrubbing Pads 3. A spoon (I know totally weird right but i’ll explain it’s use in just a bit lol) Above you see the Before on the left & After on the right!!
Step 1:
First, you’ll want to spray the product onto the oven & allow it to sit for about 5 minutes. Once, that has taken place you will then be able to start scrubbing with your heavy duty scrubbing pad.
Step 2:
if you find yourself scrubbing the same spots for a couple minutes then that is when the spoon will come in to place lol How exactly you ask? By using the spoon facing down (as shown in the picture) you will be able to lightly scrape off the grease & grime without having to put very much if any force when doing so. It will lift that which your heavy duty scrubbing pad won’t.
It will lift that which your heavy duty scrubbing pad won’t I’ve tried countless different ways to get my oven to fully removed the grease and grime many which I found online but none of them ever helped with completly removing the grease & grime from my oven.
Spring Cleaning Challenge
