How to Delete any File (windows)
 by karcinagin
Use a small program to delete any file.
Step 1: Get the program
Go here
And it is free and under 1mb in size
carlo.santos says: Dec 15, 2010. 4:26 AM
Hello....Nothing else worked, excluding this great utility: http://www.filesUnlocker.com
erikals says: Jul 17, 2009. 9:27 PM
i've had Unlocker for a while, it doesnt work on every file you try, sometimes it asks you if you want to delete the file on next reboot, sometimes it says no locking handle found, but it works OK for me. Problem is, the files that are deleted do not get sent to the Recycle bin. Is there a way to fix that?
techbilder09 says: Jan 4, 2009. 8:29 AM
you can try renaming the file... it should allow you to delete it after
ac1D says: Jul 25, 2008. 10:23 AM
this wont delete any file.
go to limewire, download some porn, you will hit some file wich dont have a delete button on them. you press right click on the file, there is no delete file option!
to delete such file, go to DOS or open a COMMAND PROMPT, go to the folder where you have this file, and type del <the file name>
here a exemple:
http://img500.imageshack.us/img500/2563/sn4kf.png
karcinagin (author) in reply to ac1DJul 25, 2008. 2:07 PM
It has always worked for me. and to use it you have to go right click then go to unlocker not delete (step 4 pic 3)
ac1D in reply to karcinaginJul 25, 2008. 2:31 PM
i did not meant to say "this wont delete any file." but "this wont work on all the file"
karcinagin (author) in reply to ac1DJul 25, 2008. 6:08 PM
ok i was confused
DELETED_bikedude880 in reply to ac1DJul 25, 2008. 11:10 AM
(removed by author or community request)
karcinagin (author) in reply to DELETED_bikedude880Jul 25, 2008. 2:05 PM
It is windows xp with TGT StyleXp software on it with Black Skin
DELETED_bikedude880 in reply to karcinaginJul 25, 2008. 2:30 PM
karcinagin (author) in reply to DELETED_bikedude880Jul 25, 2008. 6:09 PM
ok i was confused, again
ac1D in reply to karcinaginJul 26, 2008. 9:36 PM
we like to confuse you :)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
