loading
Step 6: Remove the Forearm
Push the forearm forward
Awesome! Thank you for showing how to safely work with this weapon.
<p>a shotgun is not a weapon, it is a tool with a specific purpose.</p><p>an aluminum bat is more a weapon than a 12ga shotgun</p>
Your tutorial worked like a champ, it took all the guess work out. I was able to disassemble in less then 10 minutes give or a take a few. Thanks again.
<p>I found there is no reason to, unless you need to clean in it.... </p><p>I have not found an easy way to take one apart.</p><p>perhaps they have made them disassemblable over the last 30 years.</p>
<p>Barnowl</p><p>With the components on the bench, is there any benefit in polishing the components before re assembly? Would polishing aid to a smoother action?</p>
<p>absolutely</p><p>I have had two of these, and did exactly that.</p><p>I used a fine stone to knock off all the edges, and an extra fine to polish all the sides that make contact with other metal.</p><p>upon reassembly, I had oiled it all up, and when totally assembled, I worked the slide a few thousand times watching a movie.</p><p>after that, I have NEVER had a jam or cartridge hang up. (Wish I could say the same thing about the Remington Wingmasters or 870's)</p>
<p>Great instructions. But I have a model 500A and cannot get the trigger group to come out as shown. I have the pin all the way out, the bot is positioned half way in the port as shown but the trigger assemble will not tilt from the front and come out. It seems to be caught on something but I can't see what. Any ideas? Thanks!</p>
<p>with the pin out, the trigger group is removed by tilting it up from the rear/butt end.</p><p>there are tabs that hold the front/barrel end in the receiver</p>
<p>Your directions for taking it apart works fine but the problem is getting it back together, that part BLOWS</p>
<p>Excellent instructions and focus on safety. May I ask how the magazine tube is removed? I don't yet own a 500 but plan to in the near future, and for my purposes (clay shooting) I want to remove the dowel placed in the tube that limits it's capacity to be legal for hunting.</p>
<p>In some cases you can hunt with the dowel removed. Check your local laws but here in Texas you can hunt quail with the dowel out and have that extra shell, which I usually need for those tricky birds! But for migratory birds, dove, ducks, etc you have to put the dowel back in. So know your laws and be safe out there! Happy hunting! </p>
<p>I'm not sure if you still need this, but the dowel is easily removed when the barrel is off. Point the muzzle end down, and the dowel comes out the threaded hole at the end where the barrel fastens to. Easy.</p>
Having owned one of these for many years, and knowing how easy it is to do, I must ask; Is there a specific reason you did not remove the magazine?
Great detailed breakdown, good work!
About This Instructable
411,084views
51favorites
License:
More by jsidey:How to Disassemble a Mossberg 500 Series Shotgun
Add instructable to:
